flattrakker Posted November 16, 2007 Report Posted November 16, 2007 LRD Pipes K & N Pods New Top End Head Shaved .010 100LL Av Gas what do you think i can pull. i wouldnt mind giving up some down low for top end.. what is your input. Quote
91banshee Posted November 16, 2007 Report Posted November 16, 2007 LRD PipesK & N Pods New Top End Head Shaved .010 100LL Av Gas what do you think i can pull. i wouldnt mind giving up some down low for top end.. what is your input. wel first off with just 010 off your stock head you are wasting your money running 100llav gas , you would be better off running 93 . i would stay with a 14 -41 if it was me , it really depends on what your gona be doing and what size rear tires your gona run Quote
flattrakker Posted November 16, 2007 Author Report Posted November 16, 2007 the guy at the shop said .020 is alot.. should i tell him i want 0.020 off? Quote
spike Posted November 16, 2007 Report Posted November 16, 2007 the guy at the shop said .020 is alot.. should i tell him i want 0.020 off? no, Tell him you want .030! Quote
flattrakker Posted November 16, 2007 Author Report Posted November 16, 2007 i started a new topic on that one but back to gears. im going to be running 20's for tires Quote
shee rips Posted November 16, 2007 Report Posted November 16, 2007 i am running 15/41 with 22" tires. mods in sig first gear can be a little fast in tight and/or rough trails. you need to let it rev in 5th before you shift to 6th otherwise it might not stay in the powerband right away. you get used to it quick tho. i like it now that im used to it Quote
flattrakker Posted November 16, 2007 Author Report Posted November 16, 2007 i prolly will have a little less power then you becuase you are ported.. afterall im running 22's not 20's as stated above.. should i go for 15/41? Quote
BillyRay Posted November 17, 2007 Report Posted November 17, 2007 I'm running 15/42 with my bike and love having use of all the gears. With my mods I have use of 1st some of the time but the bike is nasty fast and tops out around 80. At times I wish I had a little less porting. Quote
Wildcardracing Posted November 17, 2007 Report Posted November 17, 2007 My mods are in my sig, I'm running 14/40 with 22's and I love it. I like having a little more leg between gears but not too much top end (where can u actually get to 80 mph). I think 15/41 is a bit high for me. Quote
Coupelx Posted November 17, 2007 Report Posted November 17, 2007 running gas with a higher octane than is required, in most cases, produces less power. I have 15/41 on mine and some gears are a bit long winded towards the top end but i ride all sand so i pretty much just use 1-4 or 2-4 when racing. Quote
Stellar Performance Posted November 18, 2007 Report Posted November 18, 2007 running gas with a higher octane than is required, in most cases, produces less power. I have 15/41 on mine and some gears are a bit long winded towards the top end but i ride all sand so i pretty much just use 1-4 or 2-4 when racing. That is true.....you want to run the lowest posible octane (without pinging) to get the most power. Higher octane fuel burns cleaner, helps emissions.........and costs way more. Now if you end up advancing the timing greatly......+7 or more, you might want to run the higher octane, but other than that.......keep it simple and reliable, and save yourself some money.....run 93. :biggrin: Quote
4strokessuck Posted November 19, 2007 Report Posted November 19, 2007 My bike runs better with Avgas. Revvs higher and pulls harder. Beat all the Banshees today, especially up top. I'm running 15/41 and use 6th gear on 20" tires. I've been using that gearing when all I had was pipes, reeds and filter (lid on). I do mostly trails and dirt roads but also ride sand quarries and dirt drag. I'll admit, it is a little overgeared in the soft sand but I manage. Hope this helps. Good luck. Quote
