do it yourself! its, real fuckin easy. One of mine is in pieces right now.
Word. Race Tech seems to make a good kit for such things.
However, TCS does great work and all of my current rear shocks have been done by them. A word of caution though, if you go to their shop in-person, watch out for the folks in Lake Elsinore, there seems to be alot of imbred crap that goes on out there. :biggrin:
  • 1 month later...
So I'm trying to rebuild my yfz fronts right now, key word trying :sad: . Got them disassembled, cleaned and ready to put back together, and I realize I don't know how or how much shock oil to refill with. Do I need to purge the resivoir, then fill the body? What gives?
Anyone know if the 450 shocks with reservoirs are rebuildable, if so are they expensive to repair. I have the change to get some cheap but one is leaking!
Get ahold of gimmeeabeer on here.........he seems to like to take those things apart for fun. He's probably your best bet on the HQ. :thumbsup:
MAKE SURE THE RESI IS PRESSURIZED. That is absolutely critical. I don't know the fluid volume. I just filled mine up so that with the valving in the can the oil is a little under the circlip groove. Then i push in the seal head and set the clip. Make real sure you have good pressure in the reservoir though. If you fill it up improperly you can hydrolock the system and cause your self some headaches.
Thanks for your help through the pm's. I already hydrolocked the shocks up yesterday and it was a b*tch getting the undone. I think a sticky could be arranged if the write up was good enough with some nice pictures. Ill help if you would like. :thanks:
I would do it, but.......I don't have a camera, and my shocks are in one piece.
Maybe next time I'll put in some gold valves and do a write up.
