xXBlessedWithDeathXx Posted October 19, 2007 Report Posted October 19, 2007 I have a 2 in 1 carb and i`m not sure if its a PJ or PWK carb. whats the difference between the 2? Quote
locogato11283 Posted October 19, 2007 Report Posted October 19, 2007 I have a 2 in 1 carb and i`m not sure if its a PJ or PWK carb. whats the difference between the 2? should say towards the bottom of the carb, right above the bowls. should be some numbers and it will say pj or pwk. have you checked? Quote
jbooker82 Posted October 19, 2007 Report Posted October 19, 2007 How do you adjust the idle speed on your carb? PJ's you turn the choak Knob. PWK's there is a scew that angles up that lifts the slide a little. Quote
Snopczynski Posted October 19, 2007 Report Posted October 19, 2007 pj is a flat slide, pwk is a d-slide. #12 is a pj flat slide. #3 is a pwk d-slide Quote
Bansh-eman Posted October 19, 2007 Report Posted October 19, 2007 the PJ is an older carb that came on i think it was CR250's in the 80's Quote
xXBlessedWithDeathXx Posted October 19, 2007 Author Report Posted October 19, 2007 Thank you its a PWK. them pics and the idle screw told it all. i read on here alot that the PJ carb is hard to tune and mine was a bitch and its very sensitive with the air/fuel screw so it had me thinking that maybe its not a PWK and its a PJ. Thanks for all the responses all problems solved. Quote
