JdiZzla Posted October 16, 2007 Report Posted October 16, 2007 I have started doing motor work to my bike and now need a new clutch. My quad now has no where near 90hp that is said to be needed for a lockup...but maybe only 60hp, but i plan on many more upgrades and port work to one day be close to that 90hp. So my question is, because i need a clutch now should i buy the lockup clutch and case and run it with only the 60hp as opposed to buying a racing clutch then having to put in a lockup down the road. So can you even run a lockup with low hp, also how does a lock up work? It looks like it uses weights to create centrifugal force to lever down on the clutch plates, is that even close? Quote
wesw Posted October 16, 2007 Report Posted October 16, 2007 tusk clutch, atf type f tranny fluid, 6 heavy duty spring with that tusk clutch and an easy pull lever. will work great. save your money unless your looking for bling. Quote
00tbanshee Posted October 16, 2007 Report Posted October 16, 2007 put a F.A.S.T clutch in from jeff with heavy springs will do you just fine. been running mine for one whole season know with no problems.just make sure you have it adjusted right Quote
Snopczynski Posted October 16, 2007 Report Posted October 16, 2007 We run a cascade heavy duty clutch and a lockup in a torque ported 4mill that dynoed at 80hp, works fine. Quote
shee rips Posted October 16, 2007 Report Posted October 16, 2007 im not sure what its like, but i would think riding with a lockup would be shitty unless you actually need it. lockup cover is pretty cool lookin though. Quote
Snopczynski Posted October 16, 2007 Report Posted October 16, 2007 We took the one off that 4mill and the guy didn't like not having it. Quote
shanYE west Posted October 16, 2007 Report Posted October 16, 2007 (edited) tusk clutch, atf type f tranny fluid, 6 heavy duty spring with that tusk clutch and an easy pull lever. will work great. save your money unless your looking for bling. What he said. Its kinda hard to beat for 50 bucks. I've been running them in my bikes for awhile now with no problems at all. Edited October 16, 2007 by Fouledout421 Quote
Hilarious Posted October 16, 2007 Report Posted October 16, 2007 im not sure what its like, but i would think riding with a lockup would be shitty unless you actually need it.lockup cover is pretty cool lookin though. I have a lockup on my bike and only difference I can tell about it is my clutch doesnt slip at all. Im not saying that it would slip without the lockup on my current set up. Its an extra 400 bucks and you get a quick change cover so you dont have to pull the whole side off and that means draining your coolant too. While you're in there, might as well get a new inner hub, pressure plate, upgrade the basket and install a pankcake bearing on the adjuster. :beer: Quote
kawiking Posted October 16, 2007 Report Posted October 16, 2007 ive been running a F.A.S.T. clutch in mine for a year now..... no problems or slipping. i pretty much just drag mine so i take off in second hard.... Quote
wesw Posted October 17, 2007 Report Posted October 17, 2007 tusk clutch with 6 stiff springs $45 msr easy pull lever $45 2 qts of atf type f oil 5 bucks 95 bucks total ran it on my 80hp motor, just a thought trying to help you save some money all that stuff was off rmatv.com Quote
bansheefreak Posted October 17, 2007 Report Posted October 17, 2007 tusk clutch with 6 stiff springs $45msr easy pull lever $45 2 qts of atf type f oil 5 bucks 95 bucks total ran it on my 80hp motor, just a thought trying to help you save some money all that stuff was off rmatv.com hey thats what i have minus the easy pull.. works good for me and i leave hard in 1st..lol Quote
JdiZzla Posted October 17, 2007 Author Report Posted October 17, 2007 tusk clutch with 6 stiff springs $45msr easy pull lever $45 2 qts of atf type f oil 5 bucks 95 bucks total ran it on my 80hp motor, just a thought trying to help you save some money all that stuff was off rmatv.com Thanks for the advice thats what ill probably end up doing. also did you have the stock basket and inner/outer pressure plate things? Quote
wesw Posted October 17, 2007 Report Posted October 17, 2007 i personnally didnt i bought a billet setup. iknow bansheefreak runs stock setup doing good so far. Quote
