bansheeman1988 Posted October 15, 2007 Report Share Posted October 15, 2007 hey guys i recently got my 2000 shee running and it kinda runs like shit, idles fine but it bogs off the idle and is hard to wind up. ive been doing a lot of reading on this and lots of people have said that the choke tube that goes between the carbs is a common symptom. And now that i recall it there was no tube between my two carbs, so i am going to try that tonight and see how it works out. If that doesnt work i am thinking of lowering the needles (leaning) one clip. Ill let you know how it goes tonight. hopefully its just the choke tube. stock carbs airbox with no-toil foam filter no snorkel 280 mains stock pilots needles in the middle air screws 2 turns out pro circuit pipes 32:1 mix Quote Link to comment Share on other sites More sharing options...
BANSHEEMANIAC Posted October 18, 2007 Report Share Posted October 18, 2007 make sure your carbs are in sync. do not lean it yet, sounds like your lean. what do your plugs look like first? Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted October 19, 2007 Report Share Posted October 19, 2007 bump your pilot up to 27.5 Quote Link to comment Share on other sites More sharing options...
