Nope...and I've used the Vitos kit before, Motion Pro....
I've done a LOT of stock carb conversions...
can you shrink that sig pic? It's obnoxiously large...please!!!
Did you file the boss you tapped down flat? I use a die grinder and coarse scotchbrite pad, it's very soft aluminum.
As long as it's not stripped....you should be able to lock it down fine with the locknut supplied with the idle screw.
i will work on the size of my sig hahaha i didnt realize.. but you're right its too big
i used a drill press when i did it... first i milled the bosses flat and then drilled.... i dunno why they turned out like that... i have done alot of machine work ... maybe my drill press is out of round
i can still tighten them down but they just seemed too loose
  • 1 year later...
When i tapped the idle screw holes i noticed the screws were really loose... like the bit was one size too big??... anyone have that problem?????
i used a kit from vito's and it included the drill and tap...... :banghead:
What
  • 1 month later...
  • 1 month later...
i just got that tor removal kit also, i had no idea what it was but i had it done, anyways now my bike wont stay on? it was doing fine when i just got it back but now it shuts off? like its idle might b too low or something? can n e 1 help me put?
  • 1 month later...
i have heard that. i'm gonna use a drill for m6 x1.0
