Flanagans twin Posted October 4, 2007 Report Posted October 4, 2007 hey everyone, i recieved my clutch from jeff at fast today and i started to put it in, i cannot get the clutch plates to go fully into the the inner basket, the springs are fully tight but i cant get the damn center bolt to tighten? what are my steps on the clutch install after i have the plates on and springs on and tight?? thanks guys, this is very frustrating so just trying to see what i have to do next?!? thanks Quote
shee4speed Posted October 4, 2007 Report Posted October 4, 2007 The basket goes on first then the plates then the clutch boss and then the pressure plate with springs. Don't forget the thrust plates,Which are basicly washers. Quote
Flanagans twin Posted October 4, 2007 Author Report Posted October 4, 2007 The basket goes on first then the plates then the clutch boss and then the pressure plate with springs. Don't forget the thrust plates,Which are basicly washers. that is where i am at now, i have the springs on and torqued down..just cannot get the pressure plate to compress the clutch farther in on the basket if you know what im saying? i need to line up the arrows on the pressure plate and inner hub right? thanks Quote
Flanagans twin Posted October 4, 2007 Author Report Posted October 4, 2007 The basket goes on first then the plates then the clutch boss and then the pressure plate with springs. Don't forget the thrust plates,Which are basicly washers. i cannot get that middle bolt/nut to get tight...the clutch plates are still on the outer side of the inner basket..that means it isnt tightened down right right? my clutch lever shouldnt pull at all bcuz i have no fluid right? thanks Quote
shee4speed Posted October 4, 2007 Report Posted October 4, 2007 That is way confusing. Any pics? That would help alot. Quote
Snopczynski Posted October 4, 2007 Report Posted October 4, 2007 take the springs back off and move the hub around until it sits flat on the first fiber on top. I dont know what your talking about with the boss thing. Did you get a pancake adjuster or something? Quote
FasterThanU90 Posted October 4, 2007 Report Posted October 4, 2007 are your plates in Right?? look at them does the last outer plate shift into the basket "arms" or whatnot Quote
Flanagans twin Posted October 4, 2007 Author Report Posted October 4, 2007 ok so guys i have my clutch back into the inner basket but the clutch plates, not the silver steel parts, but the brownish plates arent pushing fully against the back of the inner basket. what exactly does the middle bolt/ screw do? do i need to tighten that down or what? thanks Quote
Flanagans twin Posted October 4, 2007 Author Report Posted October 4, 2007 are your plates in Right?? look at them does the last outer plate shift into the basket "arms" or whatnot yes they are in right and yes the last outer plate is in the basket Quote
Flanagans twin Posted October 5, 2007 Author Report Posted October 5, 2007 ok sorry for the massive confusion on this topic everyone! i got the whole clutch issue figured out but ended up snapping a spring bolt so all that means is i need to make a trip to the hardware store tomorrow. thanks to everyone that helped in this post and a special thanks to dave for all your help! you guys are great! :beer: Quote
