  • Replies 51
  • Created
  • Last Reply
Top Posters In This Topic
I never buy without Pay-Pal ! But after talking to him I could tell he was legit. Next day after recieving my money order he had axle in mail WITH a tracking # !!!!! Should be here in couple days but I have no worries about the condition or anything like that. Very upstanding guy and a breeze to deal with!!!!!! THANKS again.. :yes: :bunny:
Thanks much for the shocks!!!
Afetrmarket Parts:
LRD pipes, chrome in good shape, anodizing on silencers faded $150
35PWK Air Strykers w/K&N filters $200
6-pack rack w/flag holder $20
Pro Circuit silencers, rough looking but no dents $20
Roll Design stock length swingarm w/carrier $200
IMS blue desert tank $100
Front Works shocks w/res, comp adjust $150
Rear Works shock w/res, comp adjust $150
20-11-10 Sand skates on blue labels $80
22-8-10 Dune tracker on black labels $60
I have a complete T-Rex setup to sell as a whole or parts. 68 bore stock stroke. The deck is slightly warped and it is on its last bore. The power valves stripped but I modified them to work. It was ported by LRD. Would be good for someone that needs the head , intakes, or power valve housings and seals. $200
Stock parts from a 2000:
Gas tank $40
A-arms and tie rods $40
Radiator $100
Steering stem w/ Renthal bars $40
Seat, bluetop, black sides $60
Carbs, airbox, intakes, boots, twist throttle, cable $40
TORS removed, needs one adjuster for carb top
Rear axle $40
Blue plastic, front shaved, tank cover, radiator cover w/aluminum grill, rears are uncut but have some white spots from tipping over $80
96 frame w/Roll Design pegs, clean title, peg bolt holes have been repaired $150
I am in Southern California.
Glad I could help you guys out.
Items still available:
Desert tank $100
Stock carbs(TORS removed but one adjuster is broken), cable, twist throttle, and airbox w/boots $40 (I also found some reed spacers and intake boots I will throw in for an extra $20)
  • 4 weeks later...
