glamisaurus
Everything posted by glamisaurus
Pics sent to everyone that gave me an e-mail address. Front Elkas and arms are sold
FYI - I do not take Paypal, Post Office money order only.
Everyone that has requested pics, some things came up and I will not have them for you until thursday.
Also have Roll Design +2 arms/tie rods with triple rate Elkas C&R adjustable setup for around a 200lb. rider. I can put together a whole front end with spindles/hubs/brakes and brake line or sell separate. Price will vary. Located in So. Cal.
double post
All parts are in good useable shape. Shipping extra. I have feedback somewhere on here, search my name. Pics are on glamisdunes.com under "Complete Banshee Partout" or I can e-mail them to you. Herr Jugs dune port cylinders bored once $300 Shearer inframes painted black with Pro Circuit spark arrestor silencers $300 (left side pipe rubbed on lower front motor mount bolt and has a dent in it) Chariot intake with stock reed cages and Boyeson reeds $80 33PWKs, K&N's, outerwares, cable, 150/155/160/165/170 mains, CEL/CGL/DEK needles, 45/52 pilots $300 Chrome +2 steering stem with big bar clamps $120 Stock axle with billet locknut $120 Elka rear shock with Elka Linkage setup for 190lb. rider $500 2 complete transmissions with forks, bearings and drum $120 each Modquad head with 21 and 22cc domes $140 IMS black 5.5 gal. tank with Pingel valve $120 Stock radiator/cap $40 Terry cable billet thumb throttle $40 AC nerf bars $100 2 rear brake masters with caliper(one has extended line) $40 each Front brake master $40 Stock flywheel $60 2 CDI boxes 1-95-96, 1-97-04 $80 each Stock head $20 2 stock headlight switches $20 each
Got a used set if you are interested. Carbs, cable, K&N's with Outerwares + multiple jets/needles(CEL, CGL, DEK, mains from 150-170, 45/52 pilots) and a few other small parts. $300 Give me an e-mail for pics
Dual 8" light rack with quick release mount for a Banshee. I have the wiring harness and dual regulators also. My stator plate broke and took out some of the wires on the stator but I will include it with the deal if anyone is interested in rewinding it. My pics are to big to upload but I will e-mail them on request. $400 shipped. I only accept Post Office money order.
Expansion chambers only. No dents but the finish is a little rough. Both frame mounts had a small crack and were welded. Left pipe I cut and welded close to where the stinger slides on because it did not fit exactly right. Add a set of silencers from ebay and you would be on your way cheap. Pictures were to big to attach but I can e-mail them to you. $100 plus shipping
Pro Circuit to Shearer/CPI with dune port
glamisaurus replied to glamisaurus's topic in Jetting & Exhaust Forum
Thanks for the input. I do not mind keeping the rpm up, I just don't want a lightswitch powerband. Anybody tried both pipes on their same bike? -
Double post, Please delete
My setup: HJR dune port Pro Circuit pipes 33 PWKs Boyeson reeds Timing advance Lightened flywheel Modquad head 21cc domes I dune fast and don't worry to much about drag racing. It seems like the PCs hold the motor back a little on the top end. I did a search and some people say the Shearers have a good midrange while others say topend only. General agreement that the CPIs come on and sign off earlier. I pm'd Kevin to see what he has to say and wanted to get some other input.
Reply sent
$375 shipping included
Just split my motor apart and found the crank bearing outer race is turning in the case. The nub on the bearing is making a groove in the lower case half. Had this happen on another motor so I used my mig welder to make the nub bigger. Wondering if this is normal. This motor just had the top end done for the first time and was a bolt-on bike. The last one was a stock stroke T-Rex.
Keihin PWK 35mm Thumb throttle cable K&N w/ Outerware Includes all jets it came with plus the needle recommended by the guys here. EEK I think. $250 plus shipping Do a search for my feedback from previous buyers as I do not know how to link it. Give me an e-mail if you want a pic, it is to big to download.
Found this thing still sitting in a box in the garage. How about $400 plus shipping.
Setup for duning with 190lb. rider and stock swingarm. Zero preload, C&R adjustable New hardware for mounting reservoir included Has two trips on it. Shock was built in Jan. of this year(I can show you receipt) Located in Southern California $500
Yes
For feedback search for "stock and aftermarket parts" in the for sale section. Heading out to Glamis through Sunday so I will not be able to respond until then.
Clutch, cover, and pedal have been sold.
I would like to sell it all together.
Elka shock with linkage, recent oil change. $700 Stock trans, near new bearings, w/drum, forks, shift shaft etc. $250 Stock radiator with cap. $40 Complete clutch(inner hub, pressure plate, crank gear) with Wiseco billet basket $150 Cascade clutch cover(comes with stock impeller and pro design pump cover). $100 Hinson Billet brake pedal. $20 Stock welded crank. $75 Rear brake rotor with hub. $40 Rear hubs $20 Headlight switch $15 Pegs $15 SHIPPING NOT INCLUDED I will only accept Post Office money order Check my last for sale post for my reputation. (I don't know how to link it to this post) Located in Rancho Cucamonga (Southern California) E-mail for pictures or see them on Glamisdunes.com
The teeth on the sprocket did not fold in half like a piece of paper. They got worn thin and started bending over at the top. It put an OEM sprocket back on at the dunes and it is showing no abnormal signs of wear. The bad sprocket is in the trash so no pics.
