hello i have some questions for you guys
what dos having a head shaved do for the performance
cant you by a after market head and get different domes and is int that the same thing just more $$$$
thanks for this is a question i have wondered for a long time
:thanks:
:thanks:
Milling, or shaving the head raises compression by making the combustion
chamber smaller. In a way, the air and fuel charge are making a larger
explosion due to the smaller cumbustion chamber. Therefor making more power.
Also, the more compression you have increases the need for higher octane fuel.
A low octane fuel will burn quicker in a high compression engine causing detonation
which will lead to damage. The octane of a fuel is the resistance of it burning.
The aftermarket head has better cooling properties along with the intercangable
domes allowing you to change your compression. And they look cool too.
:beer:
The best feature with an aftermarket head is the capacity to change domes for desired compression.
Of course, if you wanted to you could buy 5 or 6 stock heads and shave them in equal increments, you could have interchangeable heads instead of domes. :yelrotflmao:
i think i will go with the after market head because of the better cooling and the interchangeable domes :biggrin:
but the stock head with interchangeable domes is pretty cool :geek:
