Rear Axle
Bandit
Anyone have a issue of the rear axle is cocked? It does not matter how tight i get the bolt, you run it down the road it comes back cocked.
Looking from the rear, the right side(brake side) will move back off the tensioner about 1/4 of inch. Could the carrier bolts have to much play in them?
if you know how to weld you can fill in the wallered out hole and then finish it off with a dremel or drill bit to make it tight again. Thats what i have done to mine(that i just had powdercoated black) then i went and bought a roundhouse -2 for 200 on ebayyyyyyyyyyyyyyyyyy :biggrin:
