Bandit Posted September 2, 2007 Report Posted September 2, 2007 Anyone have a issue of the rear axle is cocked? It does not matter how tight i get the bolt, you run it down the road it comes back cocked. Looking from the rear, the right side(brake side) will move back off the tensioner about 1/4 of inch. Could the carrier bolts have to much play in them? Quote
NYUK Posted September 2, 2007 Report Posted September 2, 2007 check the top bolt holes of your swingarm. if they are egged out that is why.common problem. just get a new swinger. roundhouse if you can afford it. stocker if not. i have a few stockers if you need one. Quote
NYUK Posted September 2, 2007 Report Posted September 2, 2007 Yes they are egged out. TIME FOR A NEW ONE, OR IT WILL KEEP HAPPENING, WORST CASE YOU THROW THE CHAIN AND WACK UP THE CASES/ Quote
shee4speed Posted September 2, 2007 Report Posted September 2, 2007 Yes they are egged out. Anyone know why they would get egged out? Quote
NYUK Posted September 2, 2007 Report Posted September 2, 2007 riding with a loose carrier bolt. one of the most important things to check on a banshee. 9 out of 10 banshees have a chain wacked engine case. always check the carrier bolts and chain slack. Quote
Bandit Posted September 2, 2007 Author Report Posted September 2, 2007 Whats a new swing arm going to cost me? Quote
NYUK Posted September 3, 2007 Report Posted September 3, 2007 i dunno about a new one i have 2 with no egging 40 shipped.for 1. Quote
letsgetthisdone Posted September 3, 2007 Report Posted September 3, 2007 if you want another stovker go with NYUK's, he isn't gonna send you bad shit. A roundhouse swinger/carrier combe will run you $650-$900 Quote
ClimbAnyHill Posted September 3, 2007 Report Posted September 3, 2007 You can find aftermarket rounhouse with carrier around $350ish... But you don't need that. Get that $40 stocker! Quote
Bandit Posted September 3, 2007 Author Report Posted September 3, 2007 I think i will get that stocker...I have a new Grizzly and dont ride the banshee much anymore.But its nice to say i have one and can ride it when i want to. And they are the coolest quads ever! Quote
trail rider Posted September 3, 2007 Report Posted September 3, 2007 if you know how to weld you can fill in the wallered out hole and then finish it off with a dremel or drill bit to make it tight again. Thats what i have done to mine(that i just had powdercoated black) then i went and bought a roundhouse -2 for 200 on ebayyyyyyyyyyyyyyyyyy :biggrin: Quote
