hi guyz,my shee is carboned(it smokes alot and hard 2 start) :confused: anyway i didnt ride it for a long time ,i just start it smthms,it really takes time 2 start and once it starts it smokez alot
(white heavy smoke) and once its started and i rev it dies ,but it only dies only tha 2 or third time i start it,then once its warm it revs fine,and i start it without choke,and if shee'z running and warm and i pull out tha choke tha shee smokez alot and just dies, :down: and while its cold and im kick starting it ,tha carbs leak a few drops,andmy jetting its fine ( jetting it stock,bike is bone stock) nthng damaged and reeds r fine, and no air leak.
tha parts listed in my sig r on tha way ,and if its not listed better(my shee is bone stock) plz help me guyz ,thnx in advance
:biggrin:
sa3o0od :evil:
How old is the fuel? If it is more than a few months old, put new fuel in, new properly gapped plugs, clean the filter, and clean the carburetors, one at a time, really good (disassemble, clean, and reassemble). That will give you a better starting point.
its the stock pipes. mine does it too. you know how they loop around, well in the bottom of that loop there is used oil from the 2 stroke cycle. when you run it hard it blows that oil out as it burns it up and it smokes like CRAZY!! its a yamaha flaw. aftermarket pipes would fix it.
