highroller355 Posted August 22, 2007 Report Share Posted August 22, 2007 my buddies bike watcha think we took apart for shift star clutch was working perfect ,its a fast clutch set up 6 months old can i put back in or should i buy new plates ? and can you buy just plates? thanks Quote Link to comment Share on other sites More sharing options...
dekker Posted August 22, 2007 Report Share Posted August 22, 2007 No pick bro Quote Link to comment Share on other sites More sharing options...
highroller355 Posted August 22, 2007 Author Report Share Posted August 22, 2007 my buddies bike watcha thinkwe took apart for shift star clutch was working perfect ,its a fast clutch set up 6 months old can i put back in or should i buy new plates ? and can you buy just plates? thanks my bad here is picture .do you think i can scuf and reuse? clutch was working perfect Quote Link to comment Share on other sites More sharing options...
dekker Posted August 22, 2007 Report Share Posted August 22, 2007 I wouldnt re use the plate but thats just me others might... and yes you can buy just the plates.... I do believe that Jeff uses oem plates in his clutches.... If u have a clymers it will tell you the specs on plate thickness ...Im sure others will chime in -Zach Quote Link to comment Share on other sites More sharing options...
bk_banshee Posted August 22, 2007 Report Share Posted August 22, 2007 buy new plates but while your at it might get new springs too. How old are the springs? https://www.onlinemicrofiche.com/Riva/shopp...ut/Viewcart.asp Quote Link to comment Share on other sites More sharing options...
fox_forma Posted August 22, 2007 Report Share Posted August 22, 2007 just curious but if the clutch was perfect when it came out why would there be any issues going back in? Quote Link to comment Share on other sites More sharing options...
Justintoxicated Posted August 22, 2007 Report Share Posted August 22, 2007 I would not use it either, how to the clutch plates look, the metal plates look burnt so I would imagine the others have some serious wear as well?. What oil were you running? Was your clutch slipping alot? My stock clutch is 7 years old and looks better than that plate. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted August 22, 2007 Report Share Posted August 22, 2007 call FAST and see what jeff says about it.. Quote Link to comment Share on other sites More sharing options...
highroller355 Posted August 23, 2007 Author Report Share Posted August 23, 2007 I would not use it either, how to the clutch plates look, the metal plates look burnt so I would imagine the others have some serious wear as well?. What oil were you running? Was your clutch slipping alot? My stock clutch is 7 years old and looks better than that plate. clutch looks great , no slipping at all, got new plates i will put back together this week thanks for the input Quote Link to comment Share on other sites More sharing options...
swrbansheeboy Posted August 23, 2007 Report Share Posted August 23, 2007 that plate looks smoked, i would replace the steels and mic the fiber's to make sure there within spec. then put in new springs for good measure. just my o-pin-ion... Quote Link to comment Share on other sites More sharing options...
badassbanshee479 Posted August 23, 2007 Report Share Posted August 23, 2007 looks like you need to change to a different oil!!! Quote Link to comment Share on other sites More sharing options...
dajogejr Posted August 23, 2007 Report Share Posted August 23, 2007 My FAST clutch went through 05 on my stock motor, 06 on my 4 mil cub and all of this year on my 10 mil cub/alky. It don't look nothin like that... Loose or worn parts, mis-adjusted....something ain't right, those things are burned up fo sho.... What do your basket, inner and outer hub look like? Springs rarely, if ever go bad... What about the adjustment....is the arm properly adjusted? I'm on my 3rd year of abuse on my clutch, badassbanshee I think has that much and more on his clutch....something mechanically doesn't add up partner. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted August 24, 2007 Report Share Posted August 24, 2007 My FAST clutch went through 05 on my stock motor, 06 on my 4 mil cub and all of this year on my 10 mil cub/alky. It don't look nothin like that... Loose or worn parts, mis-adjusted....something ain't right, those things are burned up fo sho.... What do your basket, inner and outer hub look like? Springs rarely, if ever go bad... What about the adjustment....is the arm properly adjusted? I'm on my 3rd year of abuse on my clutch, badassbanshee I think has that much and more on his clutch....something mechanically doesn't add up partner. i agree. ive been on the same FAST clutch setup for like 3 years now. when i bought it, i also bought new clutch inner and outer hub and pressure plate. if the other clutch components are worn thats more than likely the issue. Quote Link to comment Share on other sites More sharing options...
