Tapatalk Posted August 15, 2007 Report Share Posted August 15, 2007 o.k, what the hell is a stroker motor? Are they 2 strokes? I see them on all the custom and well, "Bad Ass" banshees. Anyone have a video of one running? Thanks. Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted August 15, 2007 Report Share Posted August 15, 2007 Stroker can be in a 4 stroke or a 2 stroke motor. Basically you move the rod pin on the crank flyweights to increase stroke. They dont sound any different than a stock stroked motor, so the video would be pointless unless you wanted to see how fast they are. Quote Link to comment Share on other sites More sharing options...
racer Posted August 15, 2007 Report Share Posted August 15, 2007 An engine package with a longer than factory stroke crank shaft, achieved by extending the crank pins from the crankshaft centerline radially. Quote Link to comment Share on other sites More sharing options...
Tapatalk Posted August 15, 2007 Author Report Share Posted August 15, 2007 Thanks, Reason I'm asking is because one, I dont know obviously and 2, I'm looking to buy a custom banshee soon and see alot of banshees with these stoker motors. I just want to make sure I dont buy a 4 stroke banshee. I want one that looks similar to and sound like these :biggrin: Check out the homepage video at www.atvvideos.tv Thats what i'm talking about :thumbsup: Quote Link to comment Share on other sites More sharing options...
FasterThanU90 Posted August 15, 2007 Report Share Posted August 15, 2007 also known as "throw" :kiss: Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted August 15, 2007 Report Share Posted August 15, 2007 Thanks, Reason I'm asking is because one, I dont know obviously and 2, I'm looking to buy a custom banshee soon and see alot of banshees with these stoker motors. I just want to make sure I dont buy a 4 stroke banshee. I want one that looks similar to and sound like these :biggrin: Check out the homepage video at www.atvvideos.tv Thats what i'm talking about :thumbsup: There was never a production 4 stroke banshee, did you mean 4 mm stroked banshee? Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted August 15, 2007 Report Share Posted August 15, 2007 there is no such thing as a 4 stroke banshee. so if you buy one theres a problem. Quote Link to comment Share on other sites More sharing options...
White06Shee Posted August 16, 2007 Report Share Posted August 16, 2007 o.k, what the hell is a stroker motor? Are they 2 strokes? I see them on all the custom and well, "Bad Ass" banshees. Anyone have a video of one running? Thanks. Can Be Either A 2 Stroke Or 4 Stroke Stroker Motor... Meaning It Has A Differant Rod(longer), Longer The Rod The Longer The Stroke, Some Goes With the Shorter the Rod The Shorter The Stroke Also Increases Displacement(c.c.) Quote Link to comment Share on other sites More sharing options...
KaosBanshee44 Posted August 16, 2007 Report Share Posted August 16, 2007 I'm glad they didn't make a 4 stroke banshee...lol Quote Link to comment Share on other sites More sharing options...
dajogejr Posted August 16, 2007 Report Share Posted August 16, 2007 Can Be Either A 2 Stroke Or 4 StrokeStroker Motor... Meaning It Has A Differant Rod(longer), Longer The Rod The Longer The Stroke, Some Goes With the Shorter the Rod The Shorter The Stroke Also Increases Displacement(c.c.) WRONG. A longer rod is used in conjunction with a piston that has a higher wrist pin height (795 series or blaster pistons) It lessens the rod angle on the piston...lessening the stress of it trying to push the piston through the side of the cylinder. A crank shaft that has an offset from stock location for the rod journal pin is a stroker crank. If it is 2mm off set vs. the stock location, it is a 4 mil stroker crank (2mm on Top Dead Center, 2mm on Bottom Dead Center) Quote Link to comment Share on other sites More sharing options...
FireHead Posted August 16, 2007 Report Share Posted August 16, 2007 WRONG. A longer rod is used in conjunction with a piston that has a higher wrist pin height (795 series or blaster pistons) It lessens the rod angle on the piston...lessening the stress of it trying to push the piston through the side of the cylinder. A crank shaft that has an offset from stock location for the rod journal pin is a stroker crank. If it is 2mm off set vs. the stock location, it is a 4 mil stroker crank (2mm on Top Dead Center, 2mm on Bottom Dead Center) Word. :geek: Quote Link to comment Share on other sites More sharing options...
MSBansheeDrags Posted August 16, 2007 Report Share Posted August 16, 2007 I'm glad they didn't make a 4 stroke banshee...lol actually i have heard yamaha is considering a 4-stroke 500cc banshee for the next model year or so...apparently they already have a prototype...just won't be the same though....dbr Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted August 17, 2007 Report Share Posted August 17, 2007 I cant believe he just said that. Did you know they still make the banshee, its being sold in Canada and Europe in 2008 still. They are not making a 4 stroke banshee. Quote Link to comment Share on other sites More sharing options...
ClimbAnyHill Posted August 17, 2007 Report Share Posted August 17, 2007 Hey HillClimbr, I would just reccomend to read up some more. Study the Banshee as much as possible. Not to be rude but doesn't sound like you're ready to buy a built Banshee. Know what you want, Know what you're buying, Buy when ready! Keep posting away, Keep asking away + the search button :thumbsup: Quote Link to comment Share on other sites More sharing options...
