87sheerips Posted August 11, 2007 Report Posted August 11, 2007 I have heard that a +2 braided line will work for a stock carrier +4 swinger. If not, what should I get?? Also, how many link chain will I need. I have searched and seen 116 to be about right Quote
locogato11283 Posted August 11, 2007 Report Posted August 11, 2007 yea that should be right. you may just have to run the cable a little differently. if youre not sure get a +4 cable. i know a stock length braided cable will work on a roundhouse +4 or even a +6. reason being is that on a roundhouse swingarm the brake plate sits more on top of the carrier as opposed to out back like stock is set up.. Quote
MDS2106 Posted August 11, 2007 Report Posted August 11, 2007 I put a +4 on my son's and its a little long but it still works.On my bike I put a +2 on when I changed the swingarm and It fit alot better.. Quote
87sheerips Posted August 12, 2007 Author Report Posted August 12, 2007 I put a +4 on my son's and its a little long but it still works.On my bike I put a +2 on when I changed the swingarm and It fit alot better.. Nice, well +2 it is! Quote
Snopczynski Posted August 12, 2007 Report Posted August 12, 2007 I had a stock line on my bike with a +6 swingarm and went with a +1 stainless line when I upgraded. Quote
BansheeDan Posted August 12, 2007 Report Posted August 12, 2007 (edited) I had a stock line on my bike with a +6 swingarm and went with a +1 stainless line when I upgraded. JD are u using a stock carrier or a roundhouse?? if your using a stock carrier your gonna need atleat a +6 for your +4 arm. im on stock carrier setup with a +6 and i got a line for a +10 and its only a inch or 2 too long. the stock carrier takes a longer line then a roundhouse does. on the stock carrier the caliper is mounted further back then it is on the roundhouse. Dan Edited August 12, 2007 by BansheeDan Quote
Snopczynski Posted August 12, 2007 Report Posted August 12, 2007 JD are u using a stock carrier or a roundhouse?? if your using a stock carrier your gonna need atleat a +6 for your +4 arm. im on stock carrier setup with a +6 and i got a line for a +10 and its only a inch or 2 too long. the stock carrier takes a longer line then a roundhouse does. on the stock carrier the caliper is mounted further back then it is on the roundhouse. Dan Good Point, I have a round carrier. Quote
87sheerips Posted August 12, 2007 Author Report Posted August 12, 2007 Damn, well ive always head that a +4 for a +4 stock carrier swinger is too long. Ill go with the +4 line for now, hopefully it will be fine... Quote
MDS2106 Posted August 12, 2007 Report Posted August 12, 2007 (edited) Here is a couple of pics so you can get a idea of the lenght you want.If you buy a +6 you will have to tie that s.o.b. in a knot.... +4 brakeline on a +4 swinger Edited August 12, 2007 by MDS2106 Quote
MDS2106 Posted August 12, 2007 Report Posted August 12, 2007 +2 brakeline on a +4 swinger both swingarms use stock carrier Quote
Wallrat Posted August 12, 2007 Report Posted August 12, 2007 I've got a brand new +2 galfer if you're interested. I installed it but didn't like how long it was on my +2 roundhouse so took it back off. Never had fluid in it and I'll ship it with new washers. PM me with an offer. Quote
87sheerips Posted August 13, 2007 Author Report Posted August 13, 2007 +2 brakeline on a +4 swinger both swingarms use stock carrier Well that +2 line seems to fit perfect. whats up with all the confusion on these lines, cant they come up with a standard?????? Quote
jayzx10r Posted August 13, 2007 Report Posted August 13, 2007 (edited) I have heard that a +2 braided line will work for a stock carrier +4 swinger. If not, what should I get?? Also, how many link chain will I need. I have searched and seen 116 to be about right I bought one of these +1" braided lines. Don't know how it will fit for your application but they are cheap enough at $9.99 + $5.25 shipped!! Clear coated and the shop selling them is Earl's Fittings...a well respected AN fittings retailer just blocks from my home. Friendly people there... http://cgi.ebay.com/ebaymotors/YAMAHA-BANS...1QQcmdZViewItem Edited August 13, 2007 by jayzx750 Quote
