4everwantedbanshee Posted August 10, 2007 Report Posted August 10, 2007 (edited) hey there i got a problem... i went riding yesterday and after a while i noticed my shee overheating . so i stopped and checked the level and it had no water at ALL. i filled it up and kept going by the time i got to my house the levels wa really low again...will i was trying to figure it out, oil started to come out of the trans overflow lines...so i drained the tranny and sure enough all the coolant was in there...what could be the problem a bad oil seal or maybe o-ring...or even gasket...let me know thanks Edited August 10, 2007 by 4everwantedbanshee Quote
MDS2106 Posted August 10, 2007 Report Posted August 10, 2007 (edited) Might want to pull the clutch side cover off and check the o-ring that seals the pipe into the side cover.. Edited August 10, 2007 by MDS2106 Quote
jbooker82 Posted August 10, 2007 Report Posted August 10, 2007 I would say you have a bad water pump seal. Get a new one of those and you should be good to go. Might as well get a billit aluminum water pump impeller while your in there. josh Quote
fastbanshee8 Posted August 10, 2007 Report Posted August 10, 2007 As mentioned above, it could be the o-ring, or the water pump seal. If it's the water pump seal, you might as well replace the water pump bearing while you have it apart, if that's where it's leaking, because it's a bitch to change the seal, and bearing, or at least mine was. You will need a new clutch cover gasket also. Quote
4everwantedbanshee Posted August 10, 2007 Author Report Posted August 10, 2007 i pulled off the cover and didnt see any damage on the oring or the seal but the bearing had some rust on it....how can u tell if the seal is bad...? Quote
swrbansheeboy Posted August 10, 2007 Report Posted August 10, 2007 it's like a $40 job to replace the seal and bearing on the impeller and the o-ring on the pass through. i wouldnt worry about how to check things out. if you have it torn apart you might as well just replace everything because its gonna cost you more than $40 worth of agrivation if you slap it back together half assed and still have a problem. if the bearings shot then it will chew up your new seals so just do it all while your in there so you know it's done... Quote
MILO Posted August 10, 2007 Report Posted August 10, 2007 it's like a $40 job to replace the seal and bearing on the impeller and the o-ring on the pass through. i wouldnt worry about how to check things out. if you have it torn apart you might as well just replace everything because its gonna cost you more than $40 worth of agrivation if you slap it back together half assed and still have a problem. if the bearings shot then it will chew up your new seals so just do it all while your in there so you know it's done... ditto.... if nothing else, it's a little insurance against it happening again. after you get it all together again, you might want to change the oil again a short time after to clean out as much coolant as possible from the bottom end. and beware, you might end up having clutch problems now as well. the coolant degrades the clutch fibers and the clutch will start slipping, especially in the higher gears. if you catch it before any major damage is done, you may only need a clutch kit. tusk kits are around $30-$40. Quote
4everwantedbanshee Posted August 11, 2007 Author Report Posted August 11, 2007 thaks guys i am just gunna replace all of them just to be safe... Quote
