flattrakker Posted August 7, 2007 Report Posted August 7, 2007 Ok.. I know of alot of banshees that do this but what is it. I warm my bike up, put it in first and it starts rolling, even with the clutch all the way in. What causes this and what can i do to prevent it. Is somthing worn out? Quote
jbooker82 Posted August 7, 2007 Report Posted August 7, 2007 It happnes because the clutch is dry. If it bugs you that much start it up in neutral. Quote
flattrakker Posted August 7, 2007 Author Report Posted August 7, 2007 It happnes because the clutch is dry. If it bugs you that much start it up in neutral. i do start it in neutral, but it dies somtimes when i put it in first, anyway to fix it? Quote
Bansh-eman Posted August 7, 2007 Report Posted August 7, 2007 if its hitting that hard when you shift into first your clutch isnt adjusted properly. you need to take off the clutch cover and adjust it there and not the cable. if it snaps or trys to "creep" its fine but dieing .. its grabbing too much. Quote
