i bought a banshee a few weeks ago and on the side of the motor it has trinity stage 4 stamped into it by the cylinder. i dont really know what was done to the quad or what it has for internal mods. but anyways they were runing a B9ES plug. i noticed thats not the right number.. do you think its like that for a reason like maybe it has high compression and it needs less heat. it also fouls plugs every once and a while do you think i should change them for the right plugs?? thanks for any help
its just a hotter plug probly ran it to eat up the extra oil id lean the premix ratio u can keep the style of plug try the Denso 9 thats a good plug
A 9 hear range is a colder plug and possible used in hotter months to detour detonation. I would suggest checking compression before doing too much. Yes, 8 is the stock heat range but 9 is not uncommon in the dessert.
Brandon
yea i got that backwards wooops, it could be a 9 for the high compression also yes ^^ check compression have u played with jetting?
NO, stock jets in it... all i did when i set them up was adjust the air fuel
