2004LEBanshee Posted July 23, 2007 Report Posted July 23, 2007 With my current mods I have about 184 on each cylinder compression. Am I loosing a lot of top with this. I have good low end but everyone I see seems to have less then me. I hear that lower comp pulls harder on top and high comp is for bottom end. I have a ton of bottom with this bike pulls instantly but wondering if it would be faster in a race with lower comp. Quote
locogato11283 Posted July 23, 2007 Report Posted July 23, 2007 with that higher compression you are losing some revs on top. id say drop down to about 170 lbs and youll notice a pretty big difference in revs. i run all my bikes at about 170 or 175. 180+ are stump pulling bikes that will pull huge gearing off the bottom but will suffer on top due to increased compression. what size domes are you running right now? whats your setup? Quote
2004LEBanshee Posted July 23, 2007 Author Report Posted July 23, 2007 4 mill dune port, 35 Pwk, noss head 20+2 domes, +5 timing, vF2, cpI's, Noss clamp on K&N no lid, jettin, is 45, 158, plugs look good, I had 15-41 gearing but couldnt stay in the power band when I launched in 2nd kinda bogged, on clay, went to 14 41 now it leaves hard, wheelies pretty good when it leavs, power is now. I think I need to try like 14-40. I loved the 15 for the long pulls but it was a litte slow getting to the power band. Now its instant but doesnt feel that fast. This thing feels like it has a lot more power then it did before the build, wheelies on its own through 3rd and I can pull 5th easy but doesnt really pull my buddies piped yfz that much more then it used to on the road. I dont get it. hits hard at first, I dont under stand. Quote
locogato11283 Posted July 23, 2007 Report Posted July 23, 2007 swingarm length? tires? your weight? these will all play a huge factor in how your bike leaves in 2nd.. once i know those i can give you some advice. Quote
2004LEBanshee Posted July 23, 2007 Author Report Posted July 23, 2007 stock, 20 in razors, 215, extended axle, extended a- arms. Leaves really hard now in sec, spins and wants to come up fast. more worried about the fact that I dont really pull that hard on him in the road like I thought I would. It feels way faster, but not seeing it, he is however a jocky 140 soak and wet, but that was the same when I just had, pipe, reeds, head, timing and flywheel, I was always a little faster but Im still just a little faster. doesnt make much sence. I cant think of anything I can do to get more power and still be trail able. I feel I should have enough done alread to put some good lengths down. I really dont expect to be faster in the dirt this thing is never going to hook enough to win there but I should own the road. Quote
burleybanshee Posted July 23, 2007 Report Posted July 23, 2007 Our quads are almost identical power levels I believe. I have boss intake and pods and t5 not cpi's, other than that. I have a +4 swinger to help keep the front down. I'm 230 pounds and have 15-41 gearing. IF you can handle taking off in first the 15 tooth front gear will help you pick up a lot on the road. To me it is a night and day difference when racing. Its a pain in the ass sometimes when you hit neutral shifting but the gains are big. We are in that in between power level of taking off in second gear with 15-41 on roads or dunes with 22 paddles and still needing first gear for our weight and gearing. If we had cubbys it would make up that difference and launch all day in second with out a problem. I don't want a light switch bike and I'm never going to see 180 pounds again, so I launch in first with a 15 or 2 with 14 tooth. As far as compression, I run 165 and it pulls hard, bottom to top, revs out quickly, having cpi's or shears would help it pull longer on top, but it revs out quick. Quote
2004LEBanshee Posted July 24, 2007 Author Report Posted July 24, 2007 thats what I was thinking to how do you hang with 450's on road Quote
burleybanshee Posted July 24, 2007 Report Posted July 24, 2007 I walk away from piped 450's, stroked and worked over 450's, still beat on draging on pavement, but to do a 10 top end run, no. I want to keep my engine the way it is. The four stroke can keep pulling hard on top and not over heat the engine the way a 2 stroke would. Quote
2004LEBanshee Posted July 24, 2007 Author Report Posted July 24, 2007 well then what the heck is the problem with mine should i go back up to the 15 Quote
J-Madd Posted July 24, 2007 Report Posted July 24, 2007 I'd say ditch the single carb set up, or go bigger. 35 PWK is what you'd run on a bone stock cylinder. Quote
burleybanshee Posted July 24, 2007 Report Posted July 24, 2007 If you are running a single, than ya, thats great for trail but not wide open runs on roads and dragging. The size of your main and pilot tells me its not a single though. I run a 168 main and 58 pilot in mine with cel needle differrent jetting for pipes and porting and elevation. If you are running dual 35's they are plenty for that motor. I know of a lot of drag and screaming engines that run 34pj and 35pwk's. Quote
J-Madd Posted July 24, 2007 Report Posted July 24, 2007 Yeah........I think he is running dual carbs, because he is running an airbox. When he said K&N clamp on (not clamp ons), I inferred that he had one carb, but I re-read, and I think I am wrong. Quote
wesw Posted July 25, 2007 Report Posted July 25, 2007 a 4mm dune port should pull 15-41 with 20 inch tires pretty easy, i would suggest fattent the bottom end up a bit, like a 50 pilot it might help it out. Quote
TurboBanshee420 Posted July 25, 2007 Report Posted July 25, 2007 too high of a comp for a topend built bike. Sounds like your set-up is for 7500 and up and you have a comp ratio more suited for a mid range bike. Drop the comp to 155-60 area and you'll find what you want. Quote
