Trail Tech Vapor
Put a set of risistor plugs in. BR8ES see what that does. I was getting a tach reading with out the lead pluged in to the vapor when I was running non resistor B8ES. Peggin when you reve it sounds like the tach setting needs to be set to 2 pulses per RPM.
How do you have the tach picup wired? To the orange and black wire on the coil or did you wrap the red wire around the plug wire?
I don't have the tach pickup on at the moment I had it wrapped around the spark plug... then around the wire. Tach is reading fine it is just the head unit keeps reseting. I got a set of br8es plugs. lets see if that does anything... banghead
OK! BR8ES PLUGS are a success!!!!!!!! This is my working setup for the trail-tech vapor on my banshee.
I have a 12v battery mounted against the gas tank beneath the seat bracket. I have a quick release charge setup so I can charge my battery between rides. I split the wiring harness and removed all unused connectors ( T.O.R.S. , Lights, Etc.) Rewired the tail light and head lamps into a switch wired to the positive on my battery. Grounded the lights and tail light to the battery. I ran the positive for the computer off the 12v battery to a switch then to the vapor. The tach is grounded to the header mount as well as the the radiator is grounded out to the header mount. The tach pickup is wrapped around the ingintion wire and held with a ziptie. I ran all of my wires paying special attention not to run the next to the ignition coil or the plug wires in order to keep from getting interference. I have two seperately wrapped wiring harnesses. One for ignition from my stator, and one for the 12v battery circuit.
JBooker82 Buddy if you are ever in Portland i'll buy you a beer. :cheers:
I was about to bag the whole deal, youda man.
