OK! BR8ES PLUGS are a success!!!!!!!! This is my working setup for the trail-tech vapor on my banshee.
I have a 12v battery mounted against the gas tank beneath the seat bracket. I have a quick release charge setup so I can charge my battery between rides. I split the wiring harness and removed all unused connectors ( T.O.R.S. , Lights, Etc.) Rewired the tail light and head lamps into a switch wired to the positive on my battery. Grounded the lights and tail light to the battery. I ran the positive for the computer off the 12v battery to a switch then to the vapor. The tach is grounded to the header mount as well as the the radiator is grounded out to the header mount. The tach pickup is wrapped around the ingintion wire and held with a ziptie. I ran all of my wires paying special attention not to run the next to the ignition coil or the plug wires in order to keep from getting interference. I have two seperately wrapped wiring harnesses. One for ignition from my stator, and one for the 12v battery circuit.
JBooker82 Buddy if you are ever in Portland i'll buy you a beer.
I was about to bag the whole deal, youda man.
