jack24piper Posted June 28, 2007 Report Posted June 28, 2007 the other day i started the shee and it had a low end lag. so then i noticed that the right has no smoke coming out at all. so i replaced the spark plug and the compression is fine and it is still runing like shit. o it is also stock totaly. and dont tell me to do a search. thanks Quote
91banshee Posted June 30, 2007 Report Posted June 30, 2007 the other day i started the shee and it had a low end lag. so then i noticed that the right has no smoke coming out at all. so i replaced the spark plug and the compression is fine and it is still runing like shit. o it is also stock totaly. and dont tell me to do a search. thanks check your carb , could be trash stoped up the jets ,and check your reed pedals . Quote
RZBansheeMan Posted June 30, 2007 Report Posted June 30, 2007 Try switching your plug wires from one side to the other and see if the problem goes to the left cylinder. If so it could be your coil acting up. Quote
shee4speed Posted June 30, 2007 Report Posted June 30, 2007 the other day i started the shee and it had a low end lag. so then i noticed that the right has no smoke coming out at all. so i replaced the spark plug and the compression is fine and it is still runing like shit. o it is also stock totaly. and dont tell me to do a search. thanks Probably just some shit in the carb.Give both a good cleaning and go from there. Quote
