magunit420 Posted June 2, 2007 Report Posted June 2, 2007 hey i pulled off the carbs to install my vf3s but when i got it tooken apart they wont fit my intake manifold cause i have a boost bottle and i have aftermarket reeds already so i didnt put the vf3`s on...so i bolted everything back up they way it was (i belive) but now it wont start...i got spark i put gas in threw the carb and head and it fired and ran a sec.....so i guess my carbs arnt getting gas my lines arnt plugged gas is flowing im just wondering if i couldve put something in backwards or bumped somethjing or what not...im not to familer with this area Quote
magunit420 Posted June 2, 2007 Author Report Posted June 2, 2007 hey i pulled off the carbs to install my vf3s but when i got it tooken apart they wont fit my intake manifold cause i have a boost bottle and i have aftermarket reeds already so i didnt put the vf3`s on...so i bolted everything back up they way it was (i belive) but now it wont start...i got spark i put gas in threw the carb and head and it fired and ran a sec.....so i guess my carbs arnt getting gas my lines arnt plugged gas is flowing im just wondering if i couldve put something in backwards or bumped somethjing or what not...im not to familer with this area also would laying the carbs on there side would mess anything up? Quote
magunit420 Posted June 2, 2007 Author Report Posted June 2, 2007 also would laying the carbs on there side would mess anything up? anyone sokmeone please help me Quote
ZillaRider02 Posted June 3, 2007 Report Posted June 3, 2007 anyone sokmeone please help me Sometimes if you turn them upside down, the float will hang and cause the Carb to flood. Have you removed the float bowls? Did you take the slides out of the carbs when you had them off? Quote
magunit420 Posted June 3, 2007 Author Report Posted June 3, 2007 Sometimes if you turn them upside down, the float will hang and cause the Carb to flood. Have you removed the float bowls? Did you take the slides out of the carbs when you had them off? yeah they was upside down hanging from the throttle i didnt take the slides out cause they looked clean and i havnt removed the bowls either do you suggest i start there? Quote
CenCalBanshee Posted June 11, 2007 Report Posted June 11, 2007 Did you put the little rubber tube back in that goes between the carbs. I have done it a couple times and it will make it not start Quote
XxMeltIcexX Posted June 11, 2007 Report Posted June 11, 2007 Did you put the little rubber tube back in that goes between the carbs. I have done it a couple times and it will make it not start lmao i cant even help this guy now that your avator definately wont stop teasing me :tongue: Eric Quote
5150banshee Posted June 11, 2007 Report Posted June 11, 2007 if it's not the cross over tubes then i would check the floats,cause i dont think you have a cross over but not 100 percent.i would slap new plugs in it and check the floats. Quote
XxMeltIcexX Posted June 11, 2007 Report Posted June 11, 2007 Ok: -What really happend? -Why did you pull off your carbs? - To put VF3's in? In This case ^ Does that mean you didnt change anything? -What did you change for it to not start now? -Will it start if you hold throttle open? (1/2 - WOT) -Pull that boost bottle off and put the crossover tube back on! -Why wont the VF3 reeds fit and your other aftermarket ones will? What are they?? - your making no sense, switch them out already.. Give us more info or we cant help you, Eliminating one thing at a time can help us out. Eric Quote
magunit420 Posted June 11, 2007 Author Report Posted June 11, 2007 Ok: -What really happend? -Why did you pull off your carbs? - To put VF3's in? In This case ^ Does that mean you didnt change anything? -What did you change for it to not start now? -Will it start if you hold throttle open? (1/2 - WOT) -Pull that boost bottle off and put the crossover tube back on! -Why wont the VF3 reeds fit and your other aftermarket ones will? What are they?? - your making no sense, switch them out already.. Give us more info or we cant help you, Eliminating one thing at a time can help us out. Eric i got it fixed..i had an air leak on the gromet of the boost bottle and manifold Quote
XxMeltIcexX Posted June 11, 2007 Report Posted June 11, 2007 i got it fixed..i had an air leak on the gromet of the boost bottle and manifold But you still didnt get your reeds in!? Quote
