magunit420
    Grass Valley California
    1995 Yellow and Purple ported and bored with tr5 pipes. Loves pismo beach and sand mountain. Eats hondas shits kawis
magunit420's Achievements
  1. i got it fixed..i had an air leak on the gromet of the boost bottle and manifold
  2. pt mids give off a massive bottom and mid if you give it a lower gearing and possibly a 2into 1 carb kit may help with more bottomend also......also check into a woods port job that would top it off nicely along with some good rubber you`d have a nice trail bike
  3. pt mids give off a massive bottom and mid if you give it a lower gearing and possibly a 2into 1 carb kit may help with more bottomend also......also check into a woods port job that would top it off nicely along with some good rubber you`d have a nice trail bike
  4. Like is says....34pjs witl boots pro design intake reeds boostbottle and twist throttle for your 2 into 1 carb kit
  5. 34pjs wont work cant getm dialed help right side is running way hot
  6. anyone in intrested in trading there trx250r for my mint 95 banshee agressive porting 34pjs tr6`s reeds boostbotttle cool head with a set of 10 paddles mounted on ultra light dougles chromes with mohawks upfronty along with dirt tires plus a shitload of stock and extra parts ex new electical system nuts and bolts and other stuff.....will drive anywhere in the western states will have pics up later today
  7. yeah they was upside down hanging from the throttle i didnt take the slides out cause they looked clean and i havnt removed the bowls either do you suggest i start there?
  8. anyone sokmeone please help me
  9. also would laying the carbs on there side would mess anything up?
  10. hey i pulled off the carbs to install my vf3s but when i got it tooken apart they wont fit my intake manifold cause i have a boost bottle and i have aftermarket reeds already so i didnt put the vf3`s on...so i bolted everything back up they way it was (i belive) but now it wont start...i got spark i put gas in threw the carb and head and it fired and ran a sec.....so i guess my carbs arnt getting gas my lines arnt plugged gas is flowing im just wondering if i couldve put something in backwards or bumped somethjing or what not...im not to familer with this area
  11. i just had that same problem....i checked my tranny oil and it was a bit high so i pulled the plug and changed the oil....also i think if ur bike starts too overheat it may puke a little....but correct me if im wrong someone
  12. ill take the shocks...let me know
  13. thanks for the input everyone sure do appricate it :beer:
  14. VF3`s are they worth the cash how are they different from VF2`s noticable power increase?
  15. oh yah im deffinetly gonna hook the rims up with the remover...i think they`ll like that..as far as the paint i just got 3 cans of kylon fusion its suppoes to be for plastics anyways i took a heat gun and the 11 year old decals off which was a bitch but it worked... so i just did a little sanding on the rears since they get more torture then the rest of the bike...and rattlecanned it....if i was gonna do it all over i wouldnt sand the rears because you can see every little scratch even though i used like some 300 grit papaer or something like that very smootth but anyways i would maybe take a little more time and a finer grit paper and wet sand it...but i wasnt patient enough....but for the front pllastic i just soaked them in hot hot soapy water in the tub and rinced really good and let air dry and sprayed them...they turned out like glass i was very suprised and after a week the paint should be chip resistant but i mean how much dirt and rocks hits the side and i cut the fronts and smoothed out the edges with the sander just got sick of the gay ass purple and the stock decals.. but its a good change...it looks pretty good with the chrome paddles on there..ill get somepics up
