what jetts do you have in the carbs you might lower them a size or 2.
what he said.. IMO theres noway its jetted righ tif u take filter off and it runs better... that means that u are getting to much gas for the air u are getting in so u need to go down a size or 2 on your main jet as he said above when u have filter on.. Never run without the filter even for testing its not worth it
i jus got my quad fixed and i rode it around with out the air box and air filter real quick and it was running great .. then tongiht i put it on and now it bogs... wut do i adjust and how?
I am thinking you put your filter and prefilter back in too?? Please remove the prefilter and see what happens.
Brandon
what type of filter system are you using? Stock filter with box and lid? Pro-flow kit with or with out lid? need a little more info in that department. Also... what was just fixed?
it has a k&N filter on it with the box still on ... the carbs were cleaned and adjusted ... i ran it without the filter today and it runs fine .. with the filter on it runs like shit...
Are you putting the airbox lid on when you put the filter back on?
Edited by Fouledout420
what did you get fixed? any chance it had an air leak before it got fixed so it was jetted way rich to compensate and now it's been fixed so it's running hella fat unless you dump the air to it? what set up do you have and what jet's are you running with it? you said the carb's were cleaned and adjusted so what way were they adjusted?
Edited by swrbansheeboy
