2002banshee05
Everything posted by 2002banshee05
  1. hey, i am having problems with my banshee. It starts up and will run great for about 5 minutes and then all of a sudden itjust shuts down and stops running, like its not getting gas or sumthing. Then i go to kick it over and it doesnt start. So i let it sit for about 10 minutes and then it starts right away and does the same thing over again. Any ideas of what it might be?? Thank you
  2. .. every thing is lubed and cleaned up the slides are clean .... and it sticks when its off so im thinking its the cabel .. i dont think its ever been replaced and its an 02 .. what you guys think??
  3. alright thanxz guys ... i havent had time to work on it latly sso ill try and look at it tomorrow and keep in mind wut you guys said
  4. what could be the problem .. carbs? ..
  5. how do i adjust the rear brakes
  6. thanxz alot guys
  7. does anyone know a website where i can order stock parts for my banshee. A site kinda like www.ronayers.com that has a online microfile and a breakdown of the parts, the part numbers, the prices, and pictures? thanxzz
  8. the guy who worked on it said that if it doesnt run right adjust the air mixture screws on the side of the carbs? .. which way do i turn them to allow more airflow and how much do i turn them at a time?
  9. it has a k&N filter on it with the box still on ... the carbs were cleaned and adjusted ... i ran it without the filter today and it runs fine .. with the filter on it runs like shit...
  10. well it was jetted right and running fine could it be the air mixture screws need to be adjusted??
  11. i jus got my quad fixed and i rode it around with out the air box and air filter real quick and it was running great .. then tongiht i put it on and now it bogs... wut do i adjust and how?
  12. alright... any other ideas why the gas might not be getting to the cylinders??
  13. alright cause im having trouble getting gas to the cylidners . so i thought maybe that this was the problem .... do i need anything special or can u just throw anything on there?
  14. without this choke hose will it have trouble getting gas to the cylinders??
  15. without this choke tube will it have toruble getting gas to the cylinders??
  16. is there sopossed to be a tube running from the right side of the left carb to the left side of the right carb .. like straigh across from the choke?
  17. hey i did sum work and cleaned my carbs and got everything back together and it wount start .. there is spark but i puled out the plugs and they are dry .. its not getting any gas . but theres gas in the carbs .. any ideas?
  18. okay i was reading the thread... by cuttin those wires it makes it totally useless ... even the idle screws? ause right now mines fucked up and jus revs out on its own like sum1 is giving it gas then not and giving it gas and then not .. over and over
  19. hey .. im a total newbe with my banshee. What exactly are metal things on top of the carbs ... and how do i adjust them .. also if u swap them , would it cause problems ?? also does it tell yuo wut side thay are each sopoosed to go on. please explain .. thank you
  20. im working on it tomorrow .. so you guys have any ideas of anything i should check for??
  21. yea it was sitting for a while and now ive been riding it for about a week and it started acting up and i was planning on doin all the stupid shit to it anyway on friday like carbs but it took a shit on me before i could even tune her up lol soo i was jus wondering what your guys opinoion was b.c im new to banshees and you guys should know how to trouble shoot it for me ... i finally got it to start and it doesnt idle either now i have to keep on the gas and it has no power it just boggs when i get on the throttle... also i noticed that the plugs seem a little wet .. could this b.c i had to much oil in the gas? .. also it wouldnt be doin this b.c of a bad connection with the spark plug wires could it ?
  22. every time i get to half throttle .. and now today it wount even start ... must not be getting gas through the carbs?
  23. today i rode my banshee for a while and then all of a sudden id get like half throttle and there would be no power and it jus bogs like its in a high gear or sumthing ... at first it has power and then one i get past half thorttle it gives it no more power.. any suggestions?
  24. hey , i wanna buy a graphics kit for my banshee but i need some ideas and places to get them . Does anyone have a few sites where i can order them from ??
  25. hey , i have a 2003 Kawasaki Prairie 360 4x4
