vtecjun Posted May 16, 2007 Report Posted May 16, 2007 I am pretty sure that the next thing I do to my bike is going to be a head from Jeff. I am just not sure what CC domes to get. I bought Wiseco Pro-Lite (513M06500) pistons .030 over when I rebuilt it last winter. I dont know if they are any higher compression than stock though. I had my head milled at a local machine shop but I forgot how much they took off :: . I have V Force3's, 35mm PWK's, T5's, +4 Timing and running 104 Octane with Ethanol. When I did the compression test it showed 165 on both sides. I would like to run as much compression that I can (safely) on the fuel that I am running. I have a billet basket and brand new clutch as well. This winter will be a full teardown and build but for now I would like to get what I can out of her. I ride strictly in the sand drag and hill climbs mostly. I know that porting would be the best thing to do but I cant be without her for the summer. Thanks in advance. Matt Quote
locogato11283 Posted May 16, 2007 Report Posted May 16, 2007 man to be honest, 165 isnt too bad. my cub motors are at about 170 or so. for a high revving motor you dont want super high compression because it kills some top end. high compression will give you extra grunt down low though to pull a higher gear so it can be a tradeoff. jeff will need to know your altitude to determine what dome for you to run. sounds like youre already covered in the fuel department so just call or pm jeff and see what domes he thinks you need. Quote
vtecjun Posted May 16, 2007 Author Report Posted May 16, 2007 man to be honest, 165 isnt too bad. my cub motors are at about 170 or so. for a high revving motor you dont want super high compression because it kills some top end. high compression will give you extra grunt down low though to pull a higher gear so it can be a tradeoff. jeff will need to know your altitude to determine what dome for you to run. sounds like youre already covered in the fuel department so just call or pm jeff and see what domes he thinks you need. Yeah I wasnt too sure where it should or could be if I am running that fuel. I am at sea level and we always ride on the Ocean dunes so it always stays the same altitude. Do you drag only or all around dune riding with your Cub motors? Just curious on what to build this winter. Quote
locogato11283 Posted May 16, 2007 Report Posted May 16, 2007 i run mine at dirt hillclimbs and at the dunes. yea, pretty much drag only. cub cylinders are not trail friendly, so if you wanna dune and ride trails stick with stock cylinder. if you wanna drag race more then snag a cub.. Quote
RagunCajun Posted May 16, 2007 Report Posted May 16, 2007 A port job wont mean you will be without your bike for the summer. I sent my juggs off friday and they will be here in less than 3 weeks. I dont think that's a bad tradeoff. I've never seen a ported shee so im anxious to see how mine will run. :biggrin: Quote
Snopczynski Posted May 16, 2007 Report Posted May 16, 2007 what elevation are you at? Has the motor been ported at all? Quote
Bansh-eman Posted May 16, 2007 Report Posted May 16, 2007 I am pretty sure that the next thing I do to my bike is going to be a head from Jeff. I am just not sure what CC domes to get. I bought Wiseco Pro-Lite (513M06500) pistons .030 over when I rebuilt it last winter. I dont know if they are any higher compression than stock though. I had my head milled at a local machine shop but I forgot how much they took off :: . I have V Force3's, 35mm PWK's, T5's, +4 Timing and running 104 Octane with Ethanol. When I did the compression test it showed 165 on both sides. I would like to run as much compression that I can (safely) on the fuel that I am running. I have a billet basket and brand new clutch as well. This winter will be a full teardown and build but for now I would like to get what I can out of her. I ride strictly in the sand drag and hill climbs mostly. I know that porting would be the best thing to do but I cant be without her for the summer. Thanks in advance. Matt one thing i noticed when reading you said your jugs are 30 over right? you also said that your pistons are 513M06500...that is for a normal rod crank and 65mm bore.. the issue i see is 30 over is 64.75 not 65.... so are you possitive you have that combo? unless that was a mistake i dont see those jugs hitting 160 psi... im guessing you got something confused and they are actually matched up proplery but it stuck out to me when reading the thread.. Quote
vtecjun Posted May 16, 2007 Author Report Posted May 16, 2007 one thing i noticed when reading you said your jugs are 30 over right? you also said that your pistons are 513M06500...that is for a normal rod crank and 65mm bore.. the issue i see is 30 over is 64.75 not 65.... so are you possitive you have that combo? unless that was a mistake i dont see those jugs hitting 160 psi... im guessing you got something confused and they are actually matched up proplery but it stuck out to me when reading the thread.. Maybe I am confused... on the box for the pistons it says "Clear 0.0030" I think I just assumed that they were .030 over, but now that you say it they are 65mm or .040 overs. I did the compression check properly I am pretty sure. I have never checked it on a bike before always on cars. I just took out the plug and put in the fitting that fit from my Snap-On Compression tester and kicked it until the needle stopped. They both were at 165 or so. Let me know if that helps. Totally different subject.... how much power can be made using the stock cylinders? I dont mind going a little radical, but I really like to ride and not just drag. Quote
Snopczynski Posted May 16, 2007 Report Posted May 16, 2007 you do comp test with engine warm, pull both plugs and hold the throttle wide open. The wiseco part number you provided is .040" over bore from stock piston size. Quote
bansheefreak Posted May 16, 2007 Report Posted May 16, 2007 otally different subject.... how much power can be made using the stock cylinders? I dont mind going a little radical, but I really like to ride and not just drag. you can have stock cyls so radical you can beat cubs.. but its cheaper to just get a cub at some point unless you just wanna drag in a 350 class.. so basically your stockers will work however radical you decide.. just tell your biulder whatyou want he will do it... Quote
Banshee0028 Posted May 17, 2007 Report Posted May 17, 2007 A port job wont mean you will be without your bike for the summer. I sent my juggs off friday and they will be here in less than 3 weeks. I dont think that's a bad tradeoff. I've never seen a ported shee so im anxious to see how mine will run. :biggrin: Who did you send them off to? Quote
