Ok I seem to have lost my help so I am going to put this back together myself. Just got my cylinders back from the shop and I cant wait any longer to get this beast put back together and up and running
Just a few questions for the motor experts. When I put the yamabond on the cases how long do I have before the shit dries. I dont want to get one half nice and covered and have it dry as im putting some on the other half of the case.
Also should I put some yamabond around my crank gaskets and the gasket on the chain sprocket side. I want to make sure this bish isnt going to leak.
When installing the vitos crank seals the springs should be facing out correct?
This is all I can think of right now. I will be doing this tomorrow afternoon. If I have any problems im counting on you guys to walk me through them.
Thanks.
the yamabond goes on all metal surfaces that touch... so around the outside edge and all the flat parts in the middle.. it dries farly fast but not in 5 min... just get it on ther without taking forever but dont rush it and get a half ass job either... you have enough time to put a good clean coat on both halfs and put them together...
and yes the metl springs face away from the crank on the seals...
what could be used instead of yamabond?
Damn hijacking my thread ehh lol. There is some stuff that is called 3 bond that is suppose to be just as good as yamabond. I believe the thread I made a few pages over is still there. If you wanna check It out its the one titled yamabond vs. 3 bond.
three bond "1211". i've used both and both work well. the 1211 is a little thinner and easier to work with and a little easier to clean up when you need to remove it from metal surfaces. the down side is that it costs more than yamabond. when i use the three bond i only put it on one case half. you don't need alot.
if you think about how tight your case halves fit together you will see that you only need to put sealant on one half of the cases.also anything in the bottom end that needs to be sealed tight has a rubber seal so no need to coat the seals or bearings. grab a tube of rtv sealant and steal the applicator tip to put on your tube of yamabond or whatever sealant you choose to use and put a decent bead of sealant around the bottom case half then drop the top on. just make sure the tabs on your crank bearings are all turned down so they fit into the notches on the bottom case half before you put the top on...
Remember to torque the engine in the recommended steps as well.
i'm the worst at this but i think it's 8 and 18 ft lbs. my book is at the shop...check this out...pg 144
http://www.sandwizards.com/Service_Manuals/Banshee.pdf
tighten 9-16 to 3.6 ft lbs
tighten 1-8 to 7.2 ft lbs
tighten 1-8 to 18 ft lbs
tighten 9-16 to 7.2 ft lbs
so basicly the top bolts(10 millimeter) end up being 7.2 and the bottom bolts(12 millemeter) end up being 18...
Edited by swrbansheeboy
