Just need some info...kinda little fight going on between me and some ppl.
What does the CDI box do for the banshee?
Someone says its a rev limiter
Some say it controls spark
Some say the banshee can run without it
Let me know what your thoughts are
Someone says its a rev limiter---------NO BANSHEES DONT HAVE REV LIMITER I DONT EVEN THINK ANY 2 STROKE DOES MIGHT BE WRONG
Some say it controls spark-----YES
Some say the banshee can run without it-------------NO
Thanks for the reply yes ppl have been saying it has a rev limiter
to me
quote:
Originally posted by firefighterjosh
2 strokes do not have rev limiters NONE OF THEM....the cdi box controls the spark not the rev limit
If that is the case how come if it controls the spark why will it still run the same with the cdi box unplugged?
they guy that quoted me thinks it has a rev limiter
if he thinks that a cdi box is a rev limiter then he must also think that there are cams inside the motor as well. :shoothead: And if a banshee can run without it then cdi's wouldnt be so exspensive. :shoothead: :shoothead:
CDI = Capacitor Discharge Ignition
Its your ignition box, plain and simple. Thats all it does. You can't run without one. In vehicles with a rev limiter, its programmed into the CDI. The banshee does have a rev limiter that is activated when the parking brake is engaged, but thats it. There is no high-rpm limiter. The engine will rev as high as it is physically capable of doing.
to me
The OEM Banshee CDI does not have a rev limiter in it.
The short expanation is that a CDI is a solid state computer that controls the engine spark based on crankshaft rpm via a two dimensional ignition timing map that is a plot of spark timing vs. engine rpm.
If you would like a longer, more technical explanation let me know, but based on the questions you had, I doubt the people you have been talking to would understand the longer explanation. :thumbsup:
  • 18 years later...
