you can use any led light you can find it dont hardly need any power to run... and why use this over stock.....?? cus stock lights suck... here's my led tailight
i thought you need some resistors or something like that to rig up leds???? if so what did you use
you just wire the pos and or ground ... and like the light i have has a ground on the mount .. so one wire and it works.. dont need a resistor .. its a led and it burns ot less ohms or amps.. whatever it is..
so i could just wire up say 10 leds in series and plug them in, and same for brake light, just off the other wire :thumbsup:
I bought a pair of LED License plate bolts from the local auto parts store...I think they cost like $6 and are pre-wired with a resistor. I mounted them to the "L" brackets that used to hold a number plate on and wired it to the stock harness. It's pretty cool cause it is clean looking and looks like glowing eyes from the back.
  • 3 weeks later...
Here is a pic of one. That's what my banshee used to look like(the one in the middle) :ohmy: And the light will probably be like the one on the right :thumbsup:
Where do you live, it looks like you have no neighbors...lol What's in that big tank n the background too?
