mouse Posted March 12, 2007 Report Posted March 12, 2007 new top end vitos power pistions 19 domes and compresion is 110 in both cylinders is that to low elevation is 6000 Quote
LiftdT4R Posted March 12, 2007 Report Posted March 12, 2007 Yeah, you are pretty low. My guess is that with the elevation you should be between 130-140 PSI Might be ok just to get a hone and rings, it depends. Talk to BigRed though, he knows a lot about high elevations and compression. Quote
man27 Posted March 12, 2007 Report Posted March 12, 2007 I agree that is low did you make sure the threads on the compression tester was all the way down in the head if not that will give you a false reading if so you may need to rering it. :ohmy: Quote
