csrmel Posted March 2, 2007 Report Posted March 2, 2007 i notice some guys with different mods to their banshees. tires, intakes, reeds, exhaust, heads, gearing, swinger, weight reduction, etc. is this all allowed for the stock banshee class? what about alcohol? it would be nice if there was a downloadable pdf of the rules for each class.maybe i make a pdf for you guys if i can race for free? but i still need the rules. Quote
375hp banshees Posted March 2, 2007 Report Posted March 2, 2007 i notice some guys with different mods to their banshees. tires, intakes, reeds, exhaust, heads, gearing, swinger, weight reduction, etc. is this all allowed for the stock banshee class? what about alcohol? it would be nice if there was a downloadable pdf of the rules for each class.maybe i make a pdf for you guys if i can race for free? but i still need the rules. they discussed it A little on atv florida But it was different than what I heard sat ? you spend what $3.00 on gas to get there & you want to race free :yelrotflmao: Quote
csrmel Posted March 3, 2007 Author Report Posted March 3, 2007 haha yeah im just cheap shake. also yea it would be nice to trade pdf for a race. the last race we both attend we each only got 3 runs and 1 practice :/ for $30 Quote
dynodon Posted March 3, 2007 Report Posted March 3, 2007 (edited) Could be worse, some tracks are 10.00 per pass. Or Jims track in Oklahoma, Most entry fees are 50.00 and up to I think 100.00 pay back for first place only . But he does have all the BIG boys there !!!!! The more peaple in a class, the more passes you will make. The only classes that will get two passes are th ET classes, and that because you have to dial in ! As far as the PDF, You would have to get with Jeff (535 banshee) on that, But I dont know that he would go for it, Because it would effect the purse money. Who is Fl shee on the other website ??????? Edited March 3, 2007 by dynodon Quote
ORNANGE CRUSH Posted March 3, 2007 Report Posted March 3, 2007 Could be worse, some tracks are 10.00 per pass. Or Jims track in Oklahoma, Most entry fees are 50.00 and up to I think 100.00 pay back for first place only . But he does have all the BIG boys there !!!!! The more peaple in a class, the more passes you will make. The only classes that will get two passes are th ET classes, and that because you have to dial in ! As far as the PDF, You would have to get with Jeff (535 banshee) on that, But I dont know that he would go for it, Because it would effect the purse money. Who is Fl shee on the other website ??????? stock banshee no port work to motor stock crank you must be on gas with no addetives cool heads are aloud in frame pipes are aloud any tire and plus two on swingarm stock carbs with any mod Quote
methyman Posted March 4, 2007 Report Posted March 4, 2007 STOCK CLASS: 1. All Atv's must be stock appearing, front and rear fenders can be cut. 2. Overbore no larger than .080 over stock. 3. No port work or crankcase modifications. 4. No strokers, lightened cranks or long rod cranks. 5. Stock cylinder head, any modifications 6. Any reed cage, reed petals, or reed spacer allowed. 7. Stock carburetors & manifold any modification allowed. 8. TORS system can be removed. 9. Any type exhaust pipes allowed except drag pipes, CPI (in frame) ok. 10. Any style air filter 11. Heavy duty clutch plates are allowed. 12. Ignition timing plates are allowed. 13. Stock ignition system only. Flywheel can be lightened. 14. Any sprocket or tire combination. 15. Any shock modification or shock allowed. 16. Any style swing arm, not more than 2" over stock length. 17. No aftermarket or lightened frame, only small unused brackets can be cut off 18. No wheelie bars allowed. 19. No aftermarket A arms allowed. 20. No air,electric, override or automatic shifter allowed. 21. Gasoline only: Must have .760 specific gravity or less, fuel will be checked with track hydro. 22. All Atv's are subject to tear down for non compliance of rules. 23. If you are protested and are found to be illegal, the entry fee will not be reimburst 24. If you know that a bike is illegal please protest the bike before the class begins. 25. NO SLEEVED CYLINDERS 26. If you think that a bike is illegal after running the class, you must protest immediately after class. 27. At any time the track official has the right to tear down the top 3 places. Quote
methyman Posted March 4, 2007 Report Posted March 4, 2007 ProStock Rules 1. All atv's must be stock appearing, front and rear can be cut. 2. Overbore no larger than .080" 3. No strokers,lightened cranks, or long rod cranks. 4. Porting allowed. 5. Aftermarket cylinder heads allowed. 6. Any reed cage, reed petals, or reed cage spacer allowed. 7. Any carburetors & manifold modifications allowed. 8. TORS system can be removed 9. Any type exhaust pipes allowed except drag pipes.CPI (in frame ok) 10. Any style air filter. 11. Stock ignition system, can have aftermarket CDI box. 12. Flywheel can be lightened. 13. Ignition timing plates are allowed. 14. Any spocket combination. 15. Replacement axle carriers are allowed. NO exotic materials. *Exotic materials: Titanium, Magnesium, Carbon Fiber ETC. 16. Replacement sprocket holder, disc brake holders, etc. are allowed. No exotic materials. 17. No aluminum axles or swing arms. 18. Any shock modifications are allowed. 19. Any rim or tire combination. 20. Wheelie bars allowed. 21. Swing arms over 6 inches not allowed. 22. Any style aftermarket A arms are allowed. No exotic materials. 23. No air, electric, automatic or override transmissions allowed. 24. No aftermarket frames,small unused brackets can be cut. 25. Must have front and rear working brakes. 26. Gasoline only: must have .760 specific gravity, fuel will be checked with Track hydro. 27. All atv's are subject for tear down, for non compliance of rules. 28. Heavy duty clutch plates and springs allowed. No lockups or straight cut gears. 29. At any time the track officials can tear down top three places in class. Quote
methyman Posted March 4, 2007 Report Posted March 4, 2007 350 Mod Rules 1. HAS TO HAVE A STOCK ENGINE CRADDLE 2. HAS TO BE A TRUE 350/ no strokers 54mm stroke only 3. HAS TO HAVE OEM CYCLINDERS 4.CAN'T HAVE NO MORE THAN .080 OVER BORE 5. Naturally Asperiated Only Quote
methyman Posted March 4, 2007 Report Posted March 4, 2007 Outlaw Rules 0-550cc class- anything goes 551cc and up class- anything goes TO RACE IN OUTLAW CLASS YOU MUST HAVE A VALID DRIVERS LICENSES AND PARENTS CONSENT ON WAIVER IF UNDER THE AGE OF 18 Quote
375hp banshees Posted March 4, 2007 Report Posted March 4, 2007 :thumbsup: :thumbsup: :thumbsup: :thumbsup: Quote
methyman Posted March 4, 2007 Report Posted March 4, 2007 The rules were adopted from the Georgia tracks. They have been running these rules for years. The GA boys can come down to FL and not change anything. The same with us going up there to race. Matthew Quote
dynodon Posted March 4, 2007 Report Posted March 4, 2007 (edited) Damn , Looks like we have a NEW secratary !!!!LOL Thanks Matt !!!!!!!!! Edited March 4, 2007 by dynodon Quote
375hp banshees Posted March 4, 2007 Report Posted March 4, 2007 so; stock, then 350 mod, then pro stock, in theory should be slow to fast ? Quote
csrmel Posted March 4, 2007 Author Report Posted March 4, 2007 so for the stock class, this means no aftermarket heads? Quote
