Capone Posted March 2, 2007 Report Posted March 2, 2007 I'm at 500ft elevation, I had the head shaved .020" I haven't checked compression yet. (checking tomorrow) drag ported stock cyl 66mm bore vforce3's shearers B8ES plugs Also running 99oct, 32:1 with yamalube 2R (whatever the yamaha 2stroke oil is) 35mm pwk carbs and K&N pods on it. I hope thats enough info for you to tell me what jets (pilot, main) to run and where to start my airscrews & idle screws. Thanks, JD. Quote
Capone Posted March 2, 2007 Author Report Posted March 2, 2007 #160 main, #68 pilot, air screw 1/2 turn out. idle screw 1/4 out... sound about right? Quote
jbooker82 Posted March 2, 2007 Report Posted March 2, 2007 I would say 155 main, 48 pilot, CEL needle 3rd or 4th clip position. Your air screw shoudl be in between 1 to 2 turns out. As for the idle screw is should be set just for what ever idle speed that you want. Quote
locogato11283 Posted March 2, 2007 Report Posted March 2, 2007 between 158 and 162 mains, 42 to 48 pilots..i think id start with 162 main and 45 pilot.. Quote
Capone Posted March 7, 2007 Author Report Posted March 7, 2007 http://www.bansheehq.com/forums/index.php?showtopic=74960 Quote
locogato11283 Posted March 8, 2007 Report Posted March 8, 2007 I'd try a 162 main, 45 pilot. word. Quote
