ironrhinodesign Posted February 22, 2007 Report Posted February 22, 2007 Also some new aluminum gas tanks! http://ironrhinodesign.com/store/catalog/p...;products_id=64 Quote
majicmike Posted February 22, 2007 Report Posted February 22, 2007 you want to do bussniess but you dont return phone calls or answer them Quote
ironrhinodesign Posted February 24, 2007 Author Report Posted February 24, 2007 Sorry Majic we have been super busy lately. The best way to catch us is email. [email protected]. I would love to help you out with whatever you are looking for. Quote
bansheeryder_69 Posted February 24, 2007 Report Posted February 24, 2007 Thos look bad ass. Want to sponsor me :biggrin: haha Quote
RNBRAD Posted February 24, 2007 Report Posted February 24, 2007 Those look awesome!!! What is the volume on those? Quote
ironrhinodesign Posted February 25, 2007 Author Report Posted February 25, 2007 volume is 1.5 gallons. They weigh 3 #'s Quote
375hp banshees Posted February 25, 2007 Report Posted February 25, 2007 I don't know if it's what everybody was running today but I saw atleast 3 aluminum tanks busted in one way or another today:: Quote
ironrhinodesign Posted February 26, 2007 Author Report Posted February 26, 2007 we haven't had any problems with ours breaking. I have a couple friends running them on a 20mm stroke drag bike and a triple cylinder drag bike. Both ran all weekend at Banshee Wars in Dumont without problems. These bikes vibrate harder than anything out there so if they are going to break that was the test. A lot of other people are building theres from a bunch of separate pieces all welded together. Our tanks are made from far fewer pieces so there is less weld and fewer areas to break. They were bent on a CNC press brake with proper tooling as opposed to using a hand brake that tends to put too much stress on the material when it is formed. This being said I don't think our tanks will break. If they do I'll send you out a replacement. Quote
ironrhinodesign Posted March 15, 2007 Author Report Posted March 15, 2007 Ok many people have concerns about the history of aluminum tanks cracking. Here are our new mounts that come with our tanks. These mounts bolt directly into the frame and then the tank bolts to the mounts. The two bolts are separate from each other allowing slight movement in the tank so frame twist wont crack the tanks. All of our tanks come with these mounts and we also sell them separate for people having a hard time getting there tank to stay in one piece. http://ironrhinodesign.com/store/catalog/p...products_id=131 Quote
FireHead Posted March 23, 2007 Report Posted March 23, 2007 This is probably a questions I should know the answer to, but I'm going to ask anyway. What is the advantage of using an aluminum tank like is pictured in this thread over using a stock tank? Is it primarily a weight issue or are there other reasons as well? :geek: Quote
bansheeryder_69 Posted March 27, 2007 Report Posted March 27, 2007 I always thought alcohol messed up aluminum is this true? Quote
FireHead Posted March 27, 2007 Report Posted March 27, 2007 I always thought alcohol messed up aluminum is this true? Yes it does. There are a few things that can be done to combat that though. You can either coat the inside of the tank with an aircraft sloshing sealer (like POR15) or you can have the tank anodized. The last thing that can be done is that if the aluminum the tank is made out if covered in the Alcoa AlCLAD venier, you can soak the tank in an industrial acid solution to seal the metal. :thumbsup: Quote
