baddsheee Posted December 24, 2006 Report Posted December 24, 2006 Just found that my tranny is leaking through the shifter shaft(left side of case. Is this a common problem. Is there some kind of a seal that goes on the left side of the case for the shifter. Going riding tomorrow but will be checking oil level frequesntly. Really don't want to pull clutch cover off but have a feeling I'm going ot have to. Any help will be appreciated. Got to get it ready for glamis next weekend. Thanks in advance Quote
chevy7398 Posted December 24, 2006 Report Posted December 24, 2006 Just found that my tranny is leaking through the shifter shaft(left side of case. Is this a common problem. Is there some kind of a seal that goes on the left side of the case for the shifter. Going riding tomorrow but will be checking oil level frequesntly. Really don't want to pull clutch cover off but have a feeling I'm going ot have to. Any help will be appreciated. Got to get it ready for glamis next weekend. Thanks in advance ya theres a seal there, sure you could probally get just that one but for 35 bucks you can a set that includes that one plus every other seal for your motor Quote
baddsheee Posted December 24, 2006 Author Report Posted December 24, 2006 Thanks, Chevy, Any suggestions where I can get that kit from? for all the seals Quote
Dinner Posted December 25, 2006 Report Posted December 25, 2006 You said its leaking where the shift shaft comes out of the cases? So why would you need to remove your clutch cover? All you need to do is drain the oil, remove stator cover, and remove the old seal, then put on the new one. I replaced mine not to long ago(forget how much, it was cheap for the seal though). All i did was take a scriber, pull out the old seal, oil the new one, slide it on, and then take a socket big enough to fit over the shaft, and hit that gently to seal the seal. Hope this helps :thumbsup: Dinner Quote
