So the last little while, probably ever since the winter has started, my compression just didn't seem to be as good as it once was. It would take more kicks to start, etc. When i painted my cylinders and head back in the summer i remember my domes being all scratched up, nicked, and a little whole in each dome. All the nicks, etc were from the old top-end that was in there, so i new what those were from. Not to long ago i purchased a Used Stock Head from a fellow HQ'r :thumbsup: and i finally got around to switching them today. Once getting everything torqued down, i pushed on the kicker with just my hand, and there is a lot more compression there than before. So i'm quite excited about that :biggrin: So now i just need to attach all the hoses, re-jet for the colder weather, and take her out for a rip. I was hoping it wasn't my top-end just because i had that done not too long ago, and my cylinder walls are still shiney with a little bit of carbon built up on top of the pistons :thumbsup: So once i get everything put together i'm going to take a compression test and see what it is at. I'm just happy that i don't have to buy new top-end stuff right now, and i can just spend $20 on a Cylinder Head :biggrin:
Moral Is: It doesnt hurt to check your Cylinder Head everynow and then, and replacing if need be :yelrotflmao:
And i have a question, what is that white thing under your front sprocket?
Thanks
Dinner
Edited by Dinner
It's the neutral switch cover. :beer:
:thanks:
It seems to be leaking a bit of oil from behind there. Is there a gasket behind it?
Dinner
:thanks:
Dinner
yea theres a small oring... you can take it off without stuff coming out.... its the back side to your shift drum..
:thanks:
I'll try to get over to the shop and have a look at it today.
