Hey guys what up heres the deal i need some help i want to have a diffrent set of rims with street tires for my banshee and they are selling me some stock blaster rims for my bike do you think they would fit? they are 8X8 's another thing is ive heard rumers that if u run ATF instead of motor oil the banshee runs way better, smoother shifting and all should i do the switch to ATF (Automatic Tranmission Fluid)... my last thing is im leakin break fluid well let me know what you guys
i think all yamaha atv's have the same bolt pattern, i know the yfz is same as banshee..
some guys run atf in there trannys but i use gearsaver 80w, always have always will
and i dont get what your wanting to know about the break fluid... is it the front or back resi that leaking? check your gasket and make sure its not ripped and the cap is secured well.
ok In the front were the disc is the little hose that goes connected to the brakes through which the fluid goes throgh... kind of complicated lol i no but anywayz when i squeeze my breaks it just leaks all the fluid through the bolt i want to no how i can fix it or wut the problem might b...
Front rims from a Blaster will fit a Banshee but the back are a different bolt pattern - or they were anyways for a number of years
all yamaha sport ATV's have the same rear bolt pattern EXCEPT the blaster. blasters have a 4/100 rear bolt pattern.
and the brake fluid leaking... like Bansh-eman said just get new copper washers.
i don't know anything about the ATF thing.
