bansheePQ Posted November 23, 2006 Report Share Posted November 23, 2006 lot of people have the 35mm pwk unit for 2-1 carb setup......somebody have tried a 38mm pwk??I want to know your opinion for that setup especially if somebody have tested it....thanks !! Pat. Quote Link to comment Share on other sites More sharing options...
Wallrat Posted December 2, 2006 Report Share Posted December 2, 2006 It should work fine, but on a mild engine your probably going to have a hell of a time jetting the low end. Might be better if you're running some hefty port work and/or a stroker. Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted December 2, 2006 Report Share Posted December 2, 2006 a fellow bhq member had a 2n1 38pwk on his bike but he was running a 421 cub... he likes it but he is going back to dual 35s Quote Link to comment Share on other sites More sharing options...
theeechozen1 Posted December 3, 2006 Report Share Posted December 3, 2006 Im running the 2-1 W/ a 38PWK....MX port & T-5s, it works great and has massive bottom end. Once I found the needle it really liked it woke up big time.....but I have never tried the 35mm to give you an actual comparison Quote Link to comment Share on other sites More sharing options...
FIRST BANSHEE Posted December 14, 2006 Report Share Posted December 14, 2006 I ran the 35 for awhile, then tried my 38 it has been on ever since. works great bottom to top. Quote Link to comment Share on other sites More sharing options...
Wallrat Posted December 14, 2006 Report Share Posted December 14, 2006 I had the same issue w/ my single 35. Took awhile figuring out what needle it liked. Quote Link to comment Share on other sites More sharing options...
andiefrogger Posted December 16, 2006 Report Share Posted December 16, 2006 38mm works great Quote Link to comment Share on other sites More sharing options...
racer Posted December 20, 2006 Report Share Posted December 20, 2006 I had the same issue w/ my single 35. Took awhile figuring out what needle it liked. are you still running the SS 2-1 you made a while back? Quote Link to comment Share on other sites More sharing options...
