I'm trying to get my flywheel off and I need some suggestions. I have the puller and have it threaded all the way in but when i try to get it off I have to turn the shit out of it and I am scared I'm going to mess something up. I have the topend off and put a 3/8's extention throught the rods but I am worried if i keep trying i am going to mess up the rods or the crank. I dont have an impact driver so i'm just using elbow grease.
My question is if i keep doing it this way will i mess something up? If so any suggestions would be great.
Thanks
Ron
I would say if the motor is out of the frame, take it to a repair shop and heve them do it. They shouldent charge much for that. Mine came right off, but friends have had a hell of a time getting theres off.
Good luck
Motor is still in the frame. I'm going to try putting it in grear.
Thanks
Ron
I USED A TIE DOWN STRAP... RATCHET STYLE.. WRAPED IT AROUND THE FLYWHEEL.. GRABBED AHOLD OF THE EXCESS STRAP AND TIED IT TO THE FRAME SO THAT WHEN IT TURNS WHILE UR TAKING IT OFF IT WOULDNT MOVE.. AND WHAMO.. CAME RIGHT OF.. :blush:
Good luck
My buddy and I took his off by putting an extension through the rods and then just stepped on the wrench really quick to jolt the bolt and loosen it. It didn't hurt his.
Well that didnt work. I guess I will just wait and take it up to the shop and let them do it with an impact.
EVEN THE IMPACT WONT TAKE IT OFF.. U CAN GO GET A RUBBER STYLE OIL FILTER REMOVER AND USE THAT TO HOLD THE FLYWHEEL.. USUALLY TAKES 2 PEOPLE
I CONCURRRR!!! :beer:
JUST TOOK MINE OFF THAT WAY LAST WEEK.. WENT CAMPING DIDNT HAVE MUCH
Thanks
Ron
Doesn't your flywheel puller have wrench flats on it? So that you can thread it in until it bottoms, then put a wrench across the flats to hold it from twisting while you tighten the screw that applys pressure against the end of the crank. Surely you can tighten it till it pops loose...
I am soooo stupid!!! I didnt even think of that. Thank you soooooo much!
Worked like a charm! I did the M0D to my timming plate. I will see how well I did once I get my topend back together.
Hell yeah, I was going to say, the easy way is to use the wrench part of the puller, or else, for my YZ80, I bough a flywheel holder from pepboys. Has 2 rubber coated bolts on scissor style arms that go through the whole in the face of the flywheel. That and some good old fashioned muscle. I did the timing mods on my 01 and 02, and both were a bitch and half!
