I have 2000 banshee that I recently purchased and this thing uses a lot of gas, I mean I could top it off and run one race about an 1/8 of a mile and its already about half an inch lower then the top of the tank. The other day I put nearly 3 gallons in it and went riding for about 20 mins when the bike died and I had to be towed back home. It has 34mm pwk, v-force reeds, boost bottle and some other stuff, what are your thoughts?
A buddy had the same problem as you but he was running stock carrbs though......He traced it back to the problem, which was him working on it after a case of beer.......He had the slides in backwards, the cut goes towards the air filters if you didn't know.
Try this, plug up the overflow tubes and see if it still disappears fast. If it doesn't then you know it is your float assembly wiggin' out. Make sure you check your plugs too. If may be runnin' it through the motor because something is screwed up too............ :beer:
Thanks man I'll try that!
does it seem to be running good? if the other stuff dont work run it for a couple min pull off the head pipes an see if theres gas in one of them, make sure you have spark to both cylinders. how do the plugs look?
It runs alright in the middle and top end but the lowend seems to break up some. I tried something earlier where I checked the coil for spark individually, I unplugged the left side and there was no spark while right side was on the plug, but when I did that to the right side there was spark. Is this normal?
