:beer: Nice dude, ever since I rolled mine, my subframe is even on both sides, don't think that's good, but it's stayin' that way. What kind of mark did the torxh leave on the frame, I know that cintzy powdercoat is like the easiest thing to fuck up. Nice work though man, lookin' good!
prolly should gussett that. once you bend them they will bend again really easily. especially when using heat.
using heat makes it so its not as weak.... its when you bend metal without heat that it makes it alot weaker... dont get me wrong its going to be weak reguardless casue of wrecking it
nah i think you have that backwards. when you heat metal you change its chemical properties and strength is lost. without heat would have been better.
nope ask any mechanic.... heating metal makes it so the bend its as weak...
Yeah it just ate through the stock powdercoat. Then it rusted after I washed it (forgot about it). I think if you just repaint that part you will be fine.
