foxy30 Posted November 6, 2006 Report Posted November 6, 2006 After all the problems,shee is running hard with good power.but shee is know smoking alot and started to back fire.don't know what to do with that can someone help. Quote
JustinC Posted November 6, 2006 Report Posted November 6, 2006 After all the problems,shee is running hard with good power.but shee is know smoking alot and started to back fire.don't know what to do with that can someone help. I would check the head gasket. Quote
foxy30 Posted November 6, 2006 Author Report Posted November 6, 2006 thanks,ill check that,but can't get it to idle,and the screws are all the way in,how can i fix that,shave alittle off the carb or the screws,thanks Quote
Banshee4Drag Posted November 6, 2006 Report Posted November 6, 2006 Sounds like Slides are in wrong carbs check that first... Quote
JustinC Posted November 6, 2006 Report Posted November 6, 2006 Sounds like Slides are in wrong carbs check that first... If its blowing smoke and wont idle, just by chance are you running really rich, you could just have a clogged jet, piolet check that out. Quote
dajogejr Posted November 6, 2006 Report Posted November 6, 2006 What color is the smoke? And yes, normally...if you install the idle kit on the OEM carbs, you'll have to file down the boss so the screws actually touch the slides themselves. I've had the bike backfire on me if the choke tube from one carb to the other wasn't connected...also, if the TORS isn't properly disconnected as well. Quote
foxy30 Posted November 6, 2006 Author Report Posted November 6, 2006 yes the tors r off,but the box is still there,2 plugs r unpluged, Quote
dajogejr Posted November 6, 2006 Report Posted November 6, 2006 Unplug the box under the gas tank, the two leads going into the old throttle tops (now missing) and you may have to cross the wires coming off the throttle and/or parking brake. Did you JUST remove the TORS, or...did this bike run fine before with the TORS removed? Quote
foxy30 Posted November 6, 2006 Author Report Posted November 6, 2006 I just pulled the plug from the parking brake,shee stopped bogging and started to run fine.it was just stalling out if i gave it gas,pulled them(parking)and shee started run like her old self.but ran it for a while shee started to backfire and smoke like a bitch.would the tors make it smoke and backfire like that?thanks Quote
dajogejr Posted November 6, 2006 Report Posted November 6, 2006 Smoke...probably not. Backfire, yep....sure can. It kills the ignition.... Quote
fox_forma Posted November 6, 2006 Report Posted November 6, 2006 Smoke...probably not. Backfire, yep....sure can. It kills the ignition.... couldnt the smoke be cause of the backfire? Its not burning the fuel off fast enough then when it does spark the excess blows out the back? make sense? Quote
foxy30 Posted November 6, 2006 Author Report Posted November 6, 2006 if it is unplugged,and the box is still there,is there any thing else i have to do thanks Quote
