JustinC
    99" ported, .090 pistons, milled head, revesed water flow threw cylinders, v-force, boost bottle, k&n, sst pipes, powercore2
JustinC's Achievements
  1. ah, dont do that have you just tried leaning the air fuel screw
  2. put a penny between the clutch gear and crank gear, and tighten that bitch down
  3. You can ride the river banks in Witchita, its sand, but I would go to little sahara, worth the ride, I live here as well It takes 5 hours
  4. you need to match the porting on the cases so to say, everything is sucked into the crank case, it must be opened up as well, make sure you splitt the case so debri does not get in there when porting. I would put a320 main in the stockers, yours has about what mine has, I even drilled my 320 jetts out, it made a diffrence.
  5. If its blowing smoke and wont idle, just by chance are you running really rich, you could just have a clogged jet, piolet check that out.
  6. I would check the head gasket.
  7. What is the benifit of running a wide rear, would'nt it be easier to trow a nearow rear end around a wide front than a wide rear.
  8. i SAY JUST KEEP RIDEING, AND PUSH EACH TIME TO RIDE FASTER. i FAST RIDER ON A SLOW MACHINE WILL STILL WILL STILL BE A FAST RIDER, BUT A SLOW RIDER ON A SUPER FAST MACHINE WILL JUST GO SLOWER!
  9. Thank you
  10. sounds like a gummed up jrt take the carb apart and clean the jets with a straned of speaker wire, check your reeds while carb is off, oh make sure your not running to lean, could also be bad crank seal, cannot creat any sucktion.
  11. Ok, how do I make my engin a stroker, is just the crank, and of coarse the porting, can you still run a long rod?
  12. I heard they have a new rainbow powerband set, gives allround benifits, but kinda exspensive, ask your dealer!!
  13. You have to concider weight. size of tires &rims when conpareing it would take doublein a quad to compare to a bike your wr
  14. what color is your plug, sounds like your giveing it more fuel but dont know where your needle was before, I would guess and say it needs air,
  15. You have a peice of dirt or something in your float needle and your running rich, give it a little air, then she will hit right, good luck
