foxy30
Everything posted by foxy30
  1. I put 290 mains in and it was even worse than now,so i put in the 260's in.aleast got it to run.what about the pilots,thanks man
  2. put on some fmf fatties and got her to run well,but it not the power that i had with just the stock pipes.good power in the full throttle but not really any in the bottom.bike is stock but the pipes and the reeds.little bog in the beginning then runs preety good but it has more balls with stock pipes.the mains r 270,and the pilot is stock.running it without the lid,but i don't want to do that(alot of water).can someone please help me.I'm at sea level and the temp is 25 to 50,thanks
  3. yes,everything is stock but the pipes and the reeds,gas cap is stock.it dies after 10min,then unscrew the cap it starts right up and runs fine for 10min.can i change it,or take it apart and fix it.i think the hose is fine,any help thanks
  4. went out to check her out,read some posts and i tried taking the gas cap off,ran very well with it off,can it be my gas cap not letting air in.I don't know please help
  5. hey guys- just finished rejetting for fmf fatties. went to 270 main and left the pilots at stock[25]. ran good for a coupole of days then started to boog instantly with any throttle. my elavation is 0 -stock except pipes-temperature around 40,but recently got a little colder 30-could that bve the problem any help is much appreciated
  6. foxy30
    back tires
    got your pm,and if u find anything let me know.thanks
  7. when i had the 290 main in i did have the lid on.
  8. foxy30
    back tires
    hello to all looking for a set of back tires(stock)thanks
  9. i put in the 270mains and took the airbox cover off,shee ran real well.and i'm at sea level,30 to 50 degres but i want to keep the airbox cover on.alot of water here.thanks for all the help
  10. thanks alot i'll give it a try
  11. Hay guys, have a ? about pipes.Just got some new pipes for christmas,fmf fatties.put them on and changed the main to 290,(all stock other than the pipes)just wasn't getting the pop shee had before.what should i do next,should i change the pilot,all the help the better. thanks
  12. hello again- just put on fmf fatties and powercore 2s on an 02 banshee and it seems much flatter throughout whole rpm range.rejetted main at 290,left pilots stock. I am at 0 elavation and 30 -50 degrees, air box is stock, bike is stock can anyone help
  13. foxy30
    jets
    can anyone tell me where to get individual main and pilot jets ....thanx
  14. how much for pipes and silencers after paint sorry didnt finish reading-ill give ya 180 pipes and silencers after paint....email me at [email protected]
  15. I have a 02 shee,finally got it to run.but she won't idle very well,put new plugs ih her ran great until 3and 4 gear she will start to pop start to bogg and then stall put.starts right back up,ride until it does the same thing.is it to rich or what.can anyone help me please?
  16. thanks guys, can't do much on it,i have no money,building a house on nantucket(800,000)so i'm just looking for something around 2 to3 hundred.I'm leaning to pipes,wich ones.and just got married ans she likes money.
  17. my shee is completely stock and was wondering without changing alot on her,what would be the best upgrade to get more power and what is the best?thanks
  18. it was the parking brake must have been on,but it was disconnected,for some reason it wouldn't let give it gas.unplugged it and shee run like a bat out of hell.thanks again
  19. if it is unplugged,and the box is still there,is there any thing else i have to do thanks
  20. I just pulled the plug from the parking brake,shee stopped bogging and started to run fine.it was just stalling out if i gave it gas,pulled them(parking)and shee started run like her old self.but ran it for a while shee started to backfire and smoke like a bitch.would the tors make it smoke and backfire like that?thanks
  21. just want to thank everyone who helped me,to her up and running.shee is back,but still somemore work needs to be done.thanks again
  22. yes the tors r off,but the box is still there,2 plugs r unpluged,
  23. thanks,ill check that,but can't get it to idle,and the screws are all the way in,how can i fix that,shave alittle off the carb or the screws,thanks
  24. After all the problems,shee is running hard with good power.but shee is know smoking alot and started to back fire.don't know what to do with that can someone help.
