bansheePQ Posted October 29, 2006 Report Posted October 29, 2006 like the topic said, give me your opinion about these kits for sale on ebay for 400$...is it worth the money?, reliable?....thanks! Quote
[email protected] Posted October 29, 2006 Report Posted October 29, 2006 not worth it , they make your transfer ports on the cylinders smaller because the sleeve is thicker . Best bet would be to invest in a nice port job and just bore the next size over ... Quote
helldriver Posted October 29, 2006 Report Posted October 29, 2006 (edited) i had that kit in one of my old shee, and it was good for the money its not bad it gives alot of useaable low end too alot of guys on here are gonna say it sucks because it dosent come from fast or pasion or whatever but vitos makes some good stuff, get that kit and do some porting and it will scream I never had one problem witht hat 404 set up Edited October 29, 2006 by helldriver Quote
rocketboy Posted October 29, 2006 Report Posted October 29, 2006 (edited) if it was me i would get the big bore 404 lakesmotorsports viper sleeves instead of the vitos .they have a much improved overall port design with a bridged exhaust port ,once properly ported it will make more power over a single exhaust port layout :beer:it wil lhave more exhaust area than a cheetah cub has Edited October 29, 2006 by rocketboy Quote
Tim C Posted October 31, 2006 Report Posted October 31, 2006 By the time you buy the 404 kit and have the sleeves installed you could have Cub cylinders Quote
rocketboy Posted October 31, 2006 Report Posted October 31, 2006 By the time you buy the 404 kit and have the sleeves installed you could have Cub cylinders and while that may be true to an extent ,you also would have a wild higher rpm style powerband not ideal for alot of applications or riders ,this bigger bore setup would be very versatile and yo u wouldnt need all the required goodies a cub needs either which would ultimately put you at a much higher expense.not saying its the best thing since sliced bread but if it was ported and setup right it would be a good option worht looking into for some people. :beer: Quote
badshee Posted October 31, 2006 Report Posted October 31, 2006 i've got the vito's 404 kit in mine and have a mx/trail port job and some cpi's and bigger carbs and it runs great... if the builder knows what their doing then they will open the transfers up as much as they can.. but overall i love my set up and on the same token i could've got the cubs but o well maybe ill try to get some some day.. but overall the set up is good and a good port job really brings it to life..... just my .02 Quote
jbooker82 Posted October 31, 2006 Report Posted October 31, 2006 if it was me i would get the big bore 404 lakesmotorsports viper sleeves instead of the vitos .they have a much improved overall port design with a bridged exhaust port ,once properly ported it will make more power over a single exhaust port layout :beer:it wil lhave more exhaust area than a cheetah cub has I looked in to this set up. It looks better than the vitos becuse they use the same sleeve for the standard bores too. Same cylinder for 64mm to 69mm Quote
