you would have to be a real smacked ass to thread 2 into a banshee head. order some pistons whilst figuring the electrode clearance. when you hear a clanking sound , you got them to tight.
You guys and your negativity....
Read the disclaimer. "If you don't use 1dir G3 reeds with this product, gains may be minimal."
hahaha, like the reeds have so much to do with the type of spark plug you use? :laugh:
It was a joke. Both seemed to be overhyped with little to no data to back up claims...
I think I'm going to bid on this patented product before it goes public. I already have a modification in store so you can screw it all the way in for MAXIMUM performace.
I'll sell a 1/2" drill bit with each plug, then you can use the plug holes in the head as a drill guide, and pop a few clearance holes into the top of each piston. That way you can screw it all the way down for MAXIMUM performance.
Of course gains will be minimal unless you opt for the White Lightning package that I'll offer. That will not only include the 1/2" drill bit, and 2 extra length plugs, but also some patented performace enhancing 2 stroke oil called Tekk 3000. Which by the way isn't in anyway similar to Tech 2000 from WalMart.
At all.
All yours for a one time payment of just $19.95 plus shipping and handling.
haha i know. i was joking about the joke...hey did u know that if u dont use the key switch that your bike will only rev to 8000 rpm? ha.
if i wanted to change compression easily id just drill some small holes in the dome, would that work??
i think so. the extra coolant youre introducing to the combustion chamber wont compress, there fore the little bit of air will be supre dense. becareful though. you have to drill and tap the holes for a swirling effect for the perfect mixtrure
