KlotzBanshee Posted October 9, 2006 Report Share Posted October 9, 2006 OK. So earlier this summer when I put a new clutch in, I also instaled a TM Designworks Magnetic oil drain plug. My concern came when I changed my fluid for the first time, man that magnet works! The thing was all furry with metal. Question is; is that good or bad? I mean its good that the magnet kept the stuff from running through my trans and clutch. But is it bad that there is stuff for it to catch? I put the new clutch in at the same time so I don't know if this is normal clutch brake in or something wrong. I've changed the oil a couple times since, and there was still fur on the mag, though not as much. And the bottom of my oil catch pan looks a little sparkely, is this unusual? btw - I use Bel Ray SAE 80w Clutchsaver Quote Link to comment Share on other sites More sharing options...
ssanddemon Posted October 9, 2006 Report Share Posted October 9, 2006 I had the same thing; bought the mag plug after I had been running mine for a couple of years. Freaked me out with all the steel fuzz stuck to that magnet, but I figured that it was picking up all the crud that had always dropped into the cases before I could get the oil out. Just changed oil today after three hard days of duning, just the tiniest bit of fuzz geting on the mag now. Quote Link to comment Share on other sites More sharing options...
dawarriorman Posted October 9, 2006 Report Share Posted October 9, 2006 "Fuzz" is going to happen. Just make sure theres no pieces of metal. Quote Link to comment Share on other sites More sharing options...
Ducman Posted October 9, 2006 Report Share Posted October 9, 2006 The bottom of the case is usually covered with the fuzz, its normal. Quote Link to comment Share on other sites More sharing options...
Polish Posted October 9, 2006 Report Share Posted October 9, 2006 Damn it makes me want to put a plug in the hole and get some fuzzz :geek: Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted October 9, 2006 Report Share Posted October 9, 2006 your clucth is always going to have this... its constantly be up and down shifted under pressure. the plate are moving hitting the basket gears touching... the fur is going to always be there.. but liek said above as long as there isnt any metal peices floating around your ok Quote Link to comment Share on other sites More sharing options...
