I ordered the bike clutch for my banshee from Passion Racing, pancake bearing, hd springs.. etc, everything to beef the clutch up. What all do you use with a lockup? I just found out when I shipped my motor they dropped in and broke the clutch cover, and bottom case, so a new clutch cover is 200$ I can get a lockup for 379, since my bike is pretty much dune/drag only. How would a lockup do on a hillclimb? Thanks, JD
From what I have experienced with my lockup, it is money well spent.
And with the quick change cover that comes with it, clutch adjustments
are easy to do from now on.
:beer:
do it man! I love the way mine works
so if you're working the side of a steep hill the lockup isn't hard to work with? I mean it's not all or nothing on the clutch?
lockup just keeps from lettin the clutch slip. if you plan on dragging you need to get at least a duneable override cuz its gonna be hard gettin it to shift fast. i run lockup on my 10mm cub that i hillclimb and it works great. but i also have a duneable override..
it works great but i would invest on getting a billet clutch basket. when i put my lock up on it shattered my basket and i had an extra basket an it shatered that one also so o got a billet on and it fine now
My 4mm cub was alot harder to shif after I put the lockup on.
