I cracked my engine when riding over some large stones. What would be the best way to fix it? Wedging or new engine?
did you crack it all the way through so your leaking fuilds? if not you can tig weld it and youll be good but im sure you canhave it welded either way your just taking a chance if the weld breaks lose that you lean out the moto and stick the intire thing.
